DS Audio Ionizer
IanG-UK
245
42
123
I feel so 20th Century...
...mine is red - I think it came from Discwasher.
That should prove to be a great investment. I think mine (but in the less expensive white colour) cost £10 or $12 - compared with the latest high-tech version of the ioniser costing $1800. You just need to make up a good story about the old Zerostats being technically much superior to the new ones as they are still available here for the equivalent of $60.
howiebrou
2,794
3,649
1,470
Here is another friend of mine using it on his old Basis :
DS Audio doesn't tell us what's inside the Vinyl Ionizer and we haven't opened it up for a look.
Maybe there are some tourmaline balls inside? Haha
Anyway it works and there is no downside sonically.
And the whole product design is neat & tidy. Actually I think that it looks really nice.
That looks a bit low CK.
CKKeung
3,063
3,201
1,410
Hong Kong
CKKeung
3,063
3,201
1,410
Hong Kong
Maybe I am half deaf. I do not think I hear any difference. But it certainly works. HK is very dry now. It reduces static to almost zero. Very happy with the result.
Hello adyc,
I keep on slobbering when looking at this AS2000 photo!
:p
Reactions: Mike Lavigne
Mike Lavigne
Apr 25, 2010
12,602
11,693
4,410
Maybe I am half deaf. I do not think I hear any difference. But it certainly works. HK is very dry now. I suffer a lot from static. It reduces static to almost zero. Very happy with the result.
i doubt you are half deaf.
it's possible your system, or the AS-2000, already is mitigating the static charge on your media. or something else is doing it so the delta of change is not audible.
or the rest of us are nuts.
or at least more nuts.:)
i've not used any of these negative ionizers myself, only the DIY hair dryer/Tourmaline screen device. that i tried in multiple systems with a consistent audible result.
btw; i also use an Acoustic Revive RL-30 Mk 3 Lp demagnatizer for Lps and silver disc media which also worked in a similar way but at about half the audible effect. it's sits outside my room next to my KLAUDIO record cleaner, but is rarely used.
https://www.thecableco.com/rl-30-iii-multi-large-demagnetizer.html
tima
5,865
6,936
1,400
the Upper Midwest
this does the same thing, but only momentarily. so you can't really compare it to these ionizer products.
this releases the static for a moment to eliminate static sparks at the needle drop, but has almost no effect after that. i own a Zerostat (or did.....i might have sold it) and compared it years ago to my hair dryer/Tourmaline screen device. i could not really hear any clear difference using the Zerostat or not using it other than reduced static at the start. which was very important at the time as my air bearing Rockport did have a severe static issue at certain times of the year. whereas the hair dryer effect on the music was clear and profound, even though not long lasting.
not saying it does nothing, but not close to these products in my experience.
No comparison made here as I've never used an $1800 electric de-ionizer or a hair dryer tourmaline thingie. I did use the zerostat before passing a cleaning brush over a record - sometimes it helped with removing a spot of dust.
Mike Lavigne
Apr 25, 2010
12,602
11,693
4,410
looking again, it's also possible that the DS de-ionizer is not sitting at the correct height for effectiveness. not sure how that is determined, so please correct me if it is optimized. just looking at other installations the unit is lower (the platter relatively higher) nearer the platter level.
CKKeung
3,063
3,201
1,410
Hong Kong
btw; i also use an Acoustic Revive RL-30 Mk 3 Lp demagnatizer for Lps and silver disc media which also worked in a similar way but at about half the audible effect. it's sits outside my room next to my KnsLAUDIO record cleaner, but is rarely used.
According to the DS Audio site, the Vinyl Ionizer is releasing positive AND negative ions at the same time.
https://www.ds-audio-w.biz/wp-content/uploads/2019/06/ion-001brochureEN.pdf
I have no idea why the two ions will not neutralize each another before reaching the LP surface.
Anyway, it works!
howiebrou
2,794
3,649
1,470
Here is a DS-Audio Document for Air Force turntables specifying the exact height and location for optimal use of the Ionizer.
adyc
893
416
973
The height should be alright. The manual says the distance between the surface of the platter and the bottom of the vent should be 5-20 cm. Mine is around 8 cm. To be honest, I never try to compare the sonic difference. Before using the ionizer, there is so much static every time I finish playing a record. After using it, there is no static. It definitely works as advertised.
howiebrou
2,794
3,649
1,470
It seems strange that the figures given for the Air Force tables are so accurate yet the range given in the manual is so wide?
dminches
3,481
2,859
1,410
Do you have a link to the document which shows the height for all the turntables they have catalogued?
CKKeung
3,063
3,201
1,410
Hong Kong
I just sent your document to TLi.
He wants to thank you but says that there is no recommendation for his coming AF Zero.
:rolleyes:
I told him to experiment and write one!
:p
howiebrou
2,794
3,649
1,470
:rolleyes:
:p
Yes i don't think they have a specification yet!
Kcin
662
846
275
Canada
ack
May 6, 2010
6,774
1,198
580
Boston, MA
CKKeung
3,063
3,201
1,410
Hong Kong
So why not buy that cheap ionizing device, as opposed to spending $1800 for virtually the same thing
This industrial white colour box-shaped antistatic fan is made in Mainland China and available in Hong Kong for more than 10 years.
Interestingly, when compared with similar products such as Furutech Destatic on cd and LP, the resulting sonic improvement is much less.
Therefore although it's dirt cheap (<usd50), very very few HK audiophiles are using them.
