Official Thread to Report Bugs, Concerns or Suggestions With The New Site Platform
Status
Not open for further replies.
Has anyone else been experiencing slowness with the web site over the past several days? I have, and I have seen 503 errors as well.
Not at my end
503 errors IIRC mean the server has timed out
I have found occasionally when I have logged on when our web host is doing a server back up or other server issues I have gotten the same error
We still are behind the DDoS block and I don't think any of us know for certain what ramifications come with that
I did get a message this morning from a member who got the following message and wanted to know if anyone else has seen this message...
When I went to the site this morning through Firefox I got a security warning not to proceed because of potential security risk
The details say it is only registered for sucuri.net and not WBF.
I am uncertain but wonder if our DDoS block is through sucuri.net
I had, I think the latest 503 error I saw was couple days ago.
And @ times recently the site was also sluggish for me, so you aren't alone.
I'm replying to you because you are correct in your observation.
I did not bother mentioning it myself as it was brief and inconsequential.
Yesterday I deleted all my browsing history so I couldn't locate the exact time of my few last 503 errors. But I remember two days ago for sure. Yesterday I wasn't active enough to notice any slowness if present.
Cheers,
Reactions: dminches
same here. and I produced some double and triple postings because of that flakey response
Reactions: dminches
I had a 503 error about 2 hours ago
I feel we can eliminate these recurring issues but if we go that route we could be saying good bye to our members from Hong Kong unless they use a VPN
I’ve had several over the past couple of days too, but only for a moment.
david
It may very well be. A trace route from my machine to WBF ends at a sucuri.net address.
Don't even need a traceroute actually. Check this out:
$ nslookup whatsbestforum.com
Non-authoritative answer:
Address: 192.124.249.110
$ nslookup 192.124.249.110
110.249.124.192.in-addr.arpa name = cloudproxy10110.sucuri.net.
Authoritative answers can be found from:
249.124.192.in-addr.arpa nameserver = 11.sucuridns.com.
So WBF is fronted by a Sucuri gateway, period.
As for HTTP 503, don't believe I have seen that at all. It's an error response that usually mean the plumbing of the website is clogged somewhere. It could be in Sucuri's edge location, but it's far more likely to the in WBF infrastructure itself. But at least things aren't swamped enough that it couldn't even tell you it's swamped.
What I have seen a lot though is connection timeout. This happens suddenly during normal website navigation. And once started, it will persist for 10-15min and suddenly comes back. I've always suspected it's Sucuri that's cutting me off. My practice is not to log onto a website unless I'm posting something. And once in a while during WBF login, I got a page saying my IP address has been temporarily black listed because of security concern, if that's a mistake please open a support ticket with Sucuri blah blah blah. This reinforces my hunch that Sucuri has been messing with my interaction with WBF. And for fun I tried opening the support ticket and was asked a customer userid and password. Ummm... Yeah.
As for my IP address, I don't normally obfuscate my IP at all so a quick geolocation lookup would put me right in Toronto, Canada. Security concern? Things usually come back in a short while so I just let it be, until yesterday. I was cut off all day yesterday from first thing in the morning to late at night before going to bed. In the afternoon, just for fun I tried coming in with an obfuscated IP address through Tor. And guess what? It worked. Ironic eh? Didn't stick around too much but this positively confirmed that Sucuri's been messing with me. I can understand the desire to block attacks, but I'm curious about the process that marks me as attacker. Must be rather fascinating...
The last few days have been slow or no response for me. Slow like 5 min to display or just times out. If someone can recommend a way to trouble shoot let me know. All other websites/my internet connection etc seem to just just fine. Thanks
The site has been slow for me as well the past few days
In fact Julian was changing the forum home page today and was locked out 3 times and he is in Spain
we have submitted a ticket and we are contemplating removing the DDoS block as that seems always to be where the problem lies
there is no question that in order two help solve a problem (instituting the DDoS Block) we have created another problem with the site running slowly to the extent that we are looking into the ramifications if we remove the block
You should find out exactly what type of DDoS was causing the problems before and then specifically solve for that.
I hope it can be sorted out without incurring slow response times for members. I told Steve I have no issue with using a VPN if that helps solve the issue but I obviously don’t speak for everyone who might get blocked after removal of the block.
Reactions: Steve Williams
I've had no access for about 16 hours until just now. Browser says timeout, server is busy.
Wow!
Personally for the last seven days (or more) I experienced zero issues.
It's true too that I don't hang around as much as I used to, so perhaps that comes into play, I just don't know.
I haven’t had any issues using Comcast in CA. Knock on wood. :)
Tim
I forwarded your IP address to our webhost as he requested.
If any others have been shut out can you post here so I have your IP address
So why are US ip addresses being locked out? I fully admit to not understanding any of the jargon though.
Status
