LampizatOr Golden Atlantic + TRP
christoph
4,689
4,077
825
Principality of Liechtenstein
nos and new. Gec
You tried all of the KT66, KT77 and KT88 in new and NOS? :eek:
New was the Genalex Gold Lions?
And NOS all GEC? :eek:
christoph
4,689
4,077
825
I would NOT guarantee that.
I do agree it is a psychological barrier. It is so cheap it can't be any good, right?
I pretty much always revert to it. I haven't tried any recti I find better overall. It just gives the best clarity I've heard with the least colouration.
That said there are guys on here that have tried way more rectifiers than me.
It's hard to admit it to yourself if you have dumped £400 on something that isn't as good.
This is absolutely NOT my experience.
As agreable the Potatoe Masher sounds, it is really a significant step below my top 4 recties.
Btw. I do own the Potatoe Masher and I would love to use that one instead of the more and very much more expensive recties. Especially after I need three recties ;)
christoph
4,689
4,077
825
fbs
87
91
105
Bavaria
:D:D:D:D we are crazy bunch of guys aren’t we? :p:cool:
As one of the crazy guys o_O, I hunted a ACME (think it's the regular version according to TAD) and will listen and report later my impressions...:D:cool:
Reactions: christoph and Ed_K
Zero000
2,988
1,141
478
I have a preamp that takes 5U4G. So I need three.
Give you one guess what I use in that?;)
bonzo75
22,650
13,687
2,710
London
The masher sounded better in Justin's system when he had his old preamp. I then tried in three other systems including in the Allnic phono in one and it was quite a few steps below any recti, lacking resolution and congesting information.
Justin, have you compared the masher and the KR using the Luxman pre?
Zero000
2,988
1,141
478
No. But I am very skeptical the KR would win with the Luxman.
It is still the best recti choice with the Luxman of the set of.rectis I own.
I went through some 5U4G and equivalent rectis before I even owned a Lampi. I'm confident the masher is excellent. Much better than EML 274B for instance. Waste of money that one. Sold them very quickly when I discovered the masher.
Peter Q of Audio Note likes them and I agree with him. They end up in a lot of AN amps.
Quite like the FIVRE 5U4G for a softer sound.
bonzo75
22,650
13,687
2,710
London
Your previous preamp was very low resolution. You like it but it was stopping all the goods from getting through. When you try it with the Luxman you will see
Zero000
2,988
1,141
478
No it wasn't very low resolution. It's a really good valve pre and way better than an 868 for much less money.
That KR sound thin and anaemic to me. The Luxman won't help it.
Golum
1,814
2,577
405
Lausanne, CH
I assume you can talk about preamps and the matching (good or bad) tubes in some other topic, if you agree, as this one became hectic as is, even without this preamp talk...thanks for understanding...
bonzo75
22,650
13,687
2,710
London
You want to have a Lampi thread without tube rolling and preamp matching?
Golum
1,814
2,577
405
Lausanne, CH
Ked if you add into this mess also preamps then we can also add power amps and even maybe sources which blends perfectly with entire combo and we'll have one monster thread without anybody being able to extract key info for them...just my two cents...
Reactions: dminches
Golum
1,814
2,577
405
Lausanne, CH
@Golum for clarity,the ACME 274b has a clear tight sound as opposed to warm and romantic?
I would just call it clear, detailed, spacious, airy...can't really comment on warm/romantic side of things. Hope this helps a bit..
sujay
516
219
955
Singapore
Hi, any views on RK 5U4G vs Acme 274b? I recently acquired the former and quite like it - better than the KR limited lampi edition. I also have the stock KR 274b. So wanted to get your view whether it’s worth investing in an Acme 274b
Grateful for your thoughts....thx
