Hi guys,
I just popped in a Orange fuse into my SPEC amp, I do like it, there is a slight bump in SQ compared to the stock Little Fuse.
. . . The thing I notice though is that my volume needs to be dialled up slightly more than my usual setting. Is this normal?
In my personal opinion, although I readily stipulate that I was not there with you to experience this, this is not normal. There is no theoretical basis known to me upon which a fuse change could attenuate signal amplitude.
Hi Ron,In my personal opinion, although I readily stipulate that I was not there with you to experience this, this is not normal. There is no theoretical basis known to me upon which a fuse change could attenuate signal amplitude.
You wrote that you raised the volume. Could this be fooling you into perceiving an increase in sound quality?
Right, but there are possible reasons why one would perceive this. When distortion is lowered at the same signal level, it can be perceived as a reduction of volume (one often turns the volume down when one comes up against rising distortion). If the fuse reduced some distortion/artifact level, it would result in a perception of smoother, more forgiving sound, inviting one to push the volume up to higher levels, as higher listening level is now more tolerable without that distortion present.
I think most here have probably experienced making a system upgrade, and then finding ourselves generally listening at a bot higher of a level due to the lowered amount of distortion/artifacts.
Hi Highsteam,Yes, give it most of three weeks in gear that stays at least minimally powered. Altho I’m an Audio Magic beeswax fan, I took advantage of the 3 for the price of 2 offer to see if the Orange had truly improved on the Blue, which I found intolerable. I’ve been burning in one in a PrimaLuna Dialogue preamp as a test, and it’s far enough along to have tentative opinions. First, the better direction with mine turned out to be the opposite of the instructions. No problem. Sonically, it definitely does have a degree of warmth that the Blue lacked, and staging, speed and clarity are very good, although they don’t stand out as much as with the Blue. That’s a trade off I frequently see between cool and warm fuses and cables. What’s bothering me thus far with the Orange is the sense of sedateness it’s introduced. The raw dynamics and vitality with the OEM fuse are now seemingly defused with the Orange’s sense of warm smoothness. That’s good news and bad in my view. But at the price I can afford to be patient beyond the audition period and see what develops.
PS. I just noticed Ron’s reply. I’ve also found the Orange to be softer, to require a little more on the volume knob. I haven’t measured whether that’s actually true or an artifact of the fuse’s different tonal balance. If true, it would not be surprising in my experience, although I can’t explain why it would be the case. Nothing new there.
