Sorry to hear, ack. I've seen some horrific cables out there in terms of build quality, unfortunately. The further you go into the "artisan" type products the more the risk, it's just not possible for most to thoroughly test things like custom or home made wire. I've seen cables with home made gold wire that always breaks, cables with ribbon conductors that can't flex without putting too much stress on the cable and it's terminations, power cables made out of 12g solid-core wire that will sound worse every time you bend it and eventually resistance will increase enough that it will heat up like a toaster wire. Cables with conductors that are unprotected from corrosion, because pure silk just sounds SO MUCH better vs teflon, people put bare wire in teflon tubes surrounded by air, so you get corrosion, it's just horrible.
As far as fuses, yes I'd have a hard time believing they are to spec and built properly as well.
