High-end Speakers V Headphone - you kidding me....
Legolas
1,047
399
455
France
Can the advances in headphone design we have seen in the last few years, can they really give us a sound that can compete with the best speaker systems?
I make no bones about it, I have been a headphone fan for many years, and use both every day. I enjoyed both equally. And I would be hard pressed to have to choose which I had to stuff in a boat to take to my desert island. In my opinion, the top headphones have got really close to the best speaker systems in terms of both emotional connection and enjoyment, and technical performance.
I went through the Stax electrostatics from the early Lambda mcdels, Lambda Signature, 007 MK1, 007 MK2, 009, 009s. Plus many electrostatic amplifiers both bought and made as DIY.
Electrostatics have a marvellous sense if timing and delicacy, micro detail is all right there, nothing seems to be lost. The challenge with most electrostatics for me, is the bass. It is there, it has extension down to below 20hz, but it DOES NOT have the drive to support it. It just doesn't sound like real bass, more a flat and weaker impression it is there.
Then after various visits to Can-Jam and hifi meets, I moved over to Planars with the LCD and conventional headphone amplifers. The thing that got me to do that was quite odd I guess, it was on hearing the Sennheiser HE1 headphone 50K system. That is an eletrostatic headphone and tube amplifier, but it has all the transparency you would expect from a top electrostatic, but really realistic bass and bass drive. Having heard that sound, I then used it as my 'target' and found the planars got the closest to it.
Now it has all gone a bit crazy. I am using the Aries Cerat Genus SET integrated, to drive the Audeze LCD4 directly off the OPT. The Genus has a 1/4 socket on the back for this purpose.
I can tell you, 100% that the sound out of this combination is beyond the level of the Sennheiser HE-1 system. It has the detail and speed, but more realistic mids and really solid placement of the soundstage. I can listen for hours with this combination.
Enter the Abyss TC planar magnetic headphone. This has the bass and creamy mids of the LCD4, but crucially the faster treble of the very best electrostatics, and the biggest soundstage I have ever heard on any headphone, even beyond the soundstage king - the Sennheiser HD800/820.
Here it is being powered off the back of the Moon 600i 125W integrated, which equates to about 12W at 33ohms for the Abyss impedance load. It sound marvellous.
The Abyss out of the Genus is up another notch, with typical tube goodness and accuracy of tone, yet the same bass control of the Moon 600i amplifier.
Piching this against my Zingali horns, it is close, different and yet similar. There is a lot more in common than not, which tells me the Abyss has nailed it, broke out of the 'in your head' type of presentation, and matched sonically to a decent speaker. There are some things the Abyss actually does better in my opinion. There is more detail and a closer connection to the music, if you are ok about headphone use in general. It is a nice way to enjoy music, one that is in recent years advanced so much.
Thoughts welcome....
The Abyss TC is without doubt the ultimate headphone.
LL21
14,430
2,518
1,448
Good to know...will definitely keep that in mind. Perfectly happy with Sennheiser 650D for now since i very very rarely need to listen on headphones. The system is on all evening while i work and weekends (while i work).
But if ever venture down that scary Upgrade Road, i will go check these out.
Gregadd
1,790
1,850
Metro DC
IMO as good as todays speakers are they bear no comparison to a binaural recording played over a quality pair of electrostatic headphones.
Kal Rubinson
2,362
706
1,700
NYC
www.stereophile.com
Perhaps but binaural recordings are quite rare............................even compared to multichannel. :)
Reactions: Lee
Gregadd
1,790
1,850
Metro DC
You are correct. Chesky has committed to binaural. Although they are pseudo for the most part. There are some start- ups that are are pursuing binaural.
I am sorry I did not take note of the amp or source at CAF 2019. But the Stax headphones sounded as good as any speaker I ever heard. That is with conventional stereo recordings.
Kal Rubinson
2,362
706
1,700
NYC
www.stereophile.com
I find that all headphones with conventional stereo recordings are intolerable.
Gregadd
1,790
1,850
Metro DC
The Senheiser is the most expensive headphone system of which I am aware. That is for headphone and amp/preamp. That seems hefty for the parts you get. If you evaluate from the perspective of sound quality it presents a different question.
Would you pay $50 k for the best? The answer has to be yes. Some audiophiles pay more than that for cables.
Solo listening. Let us be honest. Most critical sessions are done alone. Even if you have an audiophile buddy chances are you have disparate musical tastes.
Room treatment. Not required.
Comfort. No need for a vacuum seal or sweaty ears.
Bass. Surprisingly good but not on a par with a top notch full range speaker.
Spatial imaging Spooky good.
WAF Not a factor except cost.
Reactions: Katzky
Gregadd
1,790
1,850
Metro DC
I am not surprised. I suggest you are in a distinct minority. Perhaps that is where you want to be. I can't debate preference.
Rocoa
118
88
135
Spain
Hello,
I'm very fond of planars, specifically Audeze.
About Stax, I've owned some but I don't like the plastic coloration of the drivers. For my taste none shows " the natural state of things" as Audezes.
I've owned in my collection the full range of Audezes but I'm very happy with LCD4 now a days.
I have Sennheiser 800 and 800S, ATH W 3000 SE, Fostex 900 and many more but usually listen LCD4.
About the amps, I've owned a lot of them. Zana Deux, Woo Audio, Burson, Auralic, Cavalli, Leben, Rogue Audio, Icon Audio...and many more.
Currently I have Leben, Auralic Taurus, Burson Virtuoso 2 and micro ZOTL. For time now I only listen the David Berning micro ZOTL 2 design in my late night sessions.
This is a very special amplifier, without output transformers, and with Sennheiser 800 sounds a lot better than their top Orpheus (Oh, my God :eek:;)). It's a bargain for the price!
https://www.lineartubeaudio.com/headphone-amps
Some photos
1.zana deux.jpg 2.CAVALLI5.jpg 3.rogue.jpg 4woo.jpg 5audeze.jpeg 6.ZOTL16.jpeg
Reactions: rgmd11 and Uk Paul
cjfrbw
1,359
1,730
Pleasanton, CA
I like headphones and listen to them all the time. I have a few premium pairs.
Replace speaker setup? Purely wishful thinking. There's still no comparison. Big space, big air. Little space, little air. Turning little air into big air doesn't work just yet.
Reactions: Alrainbow
Gregadd
1,790
1,850
Metro DC
I agree there is no comparison. That conclusion takes us down different roads. Big air creates its own problems with which we are familiar. Unfortunately it all funnels to a bottleneck called the ear canal.
Kal Rubinson
2,362
706
1,700
NYC
www.stereophile.com
That is a separate issue for another time.
Granted.
Granted.
But the thing is still on my head and on my ears!
Granted.
But wrong! I went to CanJam NYC this year and sampled several headphones recommended to me by a colleague. He was right: They were remarkably undistorted, clear, balanced and detailed. They sound was also significantly less "in my head" than in the past but not one of them presented a credible soundstage. It was in my head, above my head, on either side of my head or some combination of the three. Not a one put the soundstage in front of me where it belongs or convinced me that I was in the midst of an ensemble. As a caveat, I was offered limited source material and I strongly suspect that none of it was binaural.
Sure.
I understand the appeal of headphones and I actually built my own way back in the very early stereo era before there were commercial stereo phones. I am also grateful to have decent headphones for plane trips.
steve59
356
112
150
Kal, if I may. I would have thought your appreciation for surround sound would have made headphone imaging a non issue for you and surround sound enthusiasts in general. Live and learn.
Kal Rubinson
2,362
706
1,700
NYC
www.stereophile.com
Hmmm. Did I miss a smiley in there? :cool:
Reactions: steve59
Gregadd
1,790
1,850
Metro DC
Kal I guess we can agree in theory that image should be in front. When listening through my smartphone I get precisely that. I am often fooled into thinking my bluetooth has cut off.
Headphones can give the impression you are sitting in the orchestra. But when done correctly it can be dead on. The whole point of binaural.
I see no point at this rime to enumerate the shortcomings of conventional speakers.
Kal Rubinson
2,362
706
1,700
NYC
www.stereophile.com
Then I envy you. Achieving an ideal illusion is wonderful.
Ah. Da capo. If only there were sufficient binaural sources.
Gregadd
1,790
1,850
Metro DC
F208Frank
132
74
95
New York
I have owned my Revel F208 speakers as my first intro to "nicer things" in the speaker world, but the problem is for me the room being not so ideal being the biggest bottleneck for me.
So for me, I spent all my funds into my headphone system, and my headphone system costed more than my speakers.
My streamer/M Scaler/DAC/AMP/Abyss Headphones ended up costing around: $40K
Sometimes I wonder if it was a better choice to just jump to the $50K set up from Sennheiser, the HE1.
But with that said I really enjoy my gear knowing that the room is not affecting my sound, as we all know the room is very important.
Also in the speaker world obtaining the best is an absolute money pit, where as for headphones obtaining the best, is just to not buy that BMW and instead buy the headphone gear and eating 99 cent cup noodles every day.
So for me, I took the headphone route, and love it.
I do enjoy feeling the bass rumbling to my chest with speakers though, can not deny that!
Rocoa
118
88
135
Spain
I think you've made the right decision. About the expensive Sennheiser combo, I don't think it's a good choice. I've listened it and the performance doesn't seem extraordinary to me. I've listened it I've prefered the Senn 800 wiht a very good tube amplifier, hand by hand.
Regards.
