Re-clockers....
Tim F
125
43
113
Just picked up an Ideon just to see what the fuss is about. Only the 3R but I'll put a decent psu on it before evaluation. There are a number of these coming onto the market and I'm hearing more about them.
Are you sold on the need for these?
Has anyone compared any against each other?
Cheers, Tim
Empirical Audio
1,169
207
150
Great Pacific Northwest
www.empiricalaudio.com
I use the SOtM tx-USBUlra. Makes a big difference. About $800-$1200 I think.
Reactions: Alrainbow
cmarin
202
525
1,193
Texas
Cheers, Tim
I recently installed a second reclocker in my TotalDac d1-12 mkII that is daisy chained with the first reclocker on the advice of the designer. It made a significant positive difference in my system.
You can definitely consider me sold on the need for reclockers.
CKKeung
3,062
3,200
1,410
Hong Kong
Listened to SOtM tx-USBultra and Totaldac Reclocker.
Both can give significant sonic improvement.
However, not directly compared them & the newer products such as Innuo Phornix yet.
Tim F
125
43
113
Very interesting that on audio science they pre-suppose that noise floor and small amounts of jitter are not important. There must be something going on here for these units to make improvements that a) they are not measuring or b) the results of them are actually audible or c) as they like to believe, everyone is deluded.
Golum
1,813
2,577
405
Lausanne, CH
Well from several guys now (with ears i trust) i heard that cascading two re-clockers makes a dramatic improvement across the board - so it goes hand in hand what @cmarin just said above.
I'm still awaiting to install Ideon big reclocker into server to avoid having one more box in the shelf...
Reactions: Tim F
Blackmorec
755
1,287
213
Logically, if you are going to place reclockers in series you need to ensure that the most accurate clock and superior power supply come last. I tried a reclocker with my Innuos Zenith SE which was fed by a fully optimised network stream and it was clearly a downgrade, likely to do with the power supplies i used to drive it.
Al M.
8,800
4,550
1,213
Greater Boston
They are deluded. The Audio Science forum, or at least Amir, also thinks MQA is a good thing. Nuff said.
cmarin
202
525
1,193
Texas
To be clear, both of the daisy-chained reclockers used in my totaldac d1-12 mkII setup are identical totaldac d1-digital reclockers and both are powered, along with the two dac monoblocks, by a single upgraded totaldac “live-power” power supply unit.
Reactions: CKKeung
Brucemck2
428
103
1,598
Houston area
4,702
Considering just sound quality, ignoring the politics and our beliefs, IMHO MQA is a good thing.
Al M.
8,800
4,550
1,213
Greater Boston
"and our beliefs": you mean, technical facts.
Reactions: Lagonda and bonzo75
4,702
Al M.
8,800
4,550
1,213
Greater Boston
The ones that you can easily look up, if you are interested, such that MQA is lossy compression, and that the "deblurring" of timing is bogus.
But enough of that, sorry for the distraction. This is a thread about reclockers.
Reactions: eskamobob1
Empirical Audio
1,169
207
150
I'm certainly not spending $1200 on something that may be placebo. It delivers improvement.
jackelsson
264
216
355
.de
Adding one Mutec MC3+ USB reclocker between streamer and DAC brought a clear improvement to my system in terms of resolution an realness. Experiments with a second cascaded Mutec brought even more improvements but seemed to also suck out liveliness a bit. For the time being I kept just one of the Mutec reclockers but will certainly experiment with cascading again.
Reactions: HTMUSIC
Empirical Audio
1,169
207
150
By the way Empirical what's this about? EMO EN-70e isolator
This is an inexpensive way to get an improvement. Use a short Ethernet cable from a router to the isolator and then a longer cable from isolator to a switch. This eliminates most of the capacitively coupled noise.
Tim F
125
43
113
Ah thanks that's useful info. I'm running Wifi into my streamer at the moment. :)
Roasty
13
11
68
42
I am using the sotm txusbultra with mods. Has anyone compared the txusbultra with the (more expensive) innuos phoenix reclocker? There is a local dealer who has brand new sealed sets, but no demo unit in the shop, and also no home audition available..
Reactions: BigAlMc
