The Sound of Analog, the Sound of Digital
the sound of Tao
3,641
4,896
940
Reactions: Lagonda
morricab
9,533
5,071
1,228
Switzerland
Should we conclude that differences in signal cables , power cables and anything that is not pure SET or vinyl distortion are due to "synthetic" artifacts?
Anything electrical will produce artifacts that are not found in nature that will therefore sound synthetic unless somehow masked. Cables, being passive, is more likely being the case that the best ones minimize the kinds of interactions between fields and materials that result in audible artifacts and also that suppress the retransmission of RFI.
SETs produce plenty of artifacts but they are of a nature, well within their power envelope, that is more maskable by the human ear/brain.
Electromechanical systems (speakers and phono cartridges) will have easier to live with (even if highly audible) artifacts as they are mostly of a mechanical nature...the electrical distortions being primarily low order. With vinyl, a major source of unnatural artifact comes from the TT drive and imperfect speed of the disk, which can lead to rather unnatural changes in pitch and timing. Another point is the need for a phono stage, which can destroy an otherwise great TT rig.
Reactions: tima
morricab
9,533
5,071
1,228
Switzerland
Exactly my point. Since long it is known that there is no subjective correlation with minimization of THD and we have no established solid alternatives - it is simple to say there is hypothetically a preferred pattern of distortion, but the subject is still controversial.
IMHO someone becomes an expert in such matters and is recognized as so if he has a continuous and persistent work on the area, recognized and referred by his peers.
An occasional interesting paper concluding that
The main point to be made, however, is that now that we have a metric with a high degree of stability and predictability we can begin to do a whole array of subjective studies of distortion mechanisms that were heretofore impossible to quantify for lack of a value yardstick with which to measure the results. (quoted from the Geddes paper)
is not enough IMHO, YMMV.
Unfortunately as far as I know these anticipated studies were never carried or published, Geddes and Lee interests moved away from amplifiers.
Yes, pity. But he always was primarily a speaker guy.
I also don’t think you need to publish persistently in a given field for a long time for a paper to have significant merit. Indeed it is often someone from OUTSIDE a given area that has the interesting insights. That is their first or only paper doesn’t lessen the scientific validity unless large mistakes can be identified.
Lagonda
3,515
4,827
1,255
Denmark
Or enhance it ! ;)
Reactions: microstrip
Folsom
6,030
1,503
550
Eastern WA
OMG. I think to myself the world has gone crazy. Then I read more totally insane “artifact” claims from Brad and think... the world has some catching up to do.
morricab
9,533
5,071
1,228
Switzerland
If you prefer distortion i can change the word...you are about the only one who doesn't seem to understand...
rbbert
3,820
239
1,000
Reno, NV
For those that are 'only digital media' here on the forum:
Do you use analog preamp and analog (passive or active) speaker crossovers? If so any comments on why?
In HiFi digital playback has by most accounts become really good lately, yet it seems to be very very rare for anyone to run a fully digital rig (volume/crossovers/dsp processing etc.) up to the amps/speakers. I know Sharp did it ages ago but that isn't a main player in our wheelhouse...
Pro audio (studio and pa) routinely use this sort of implentation.
If there is A>D conversion there should also be D>A conversion somewhere in the electronic chain, does it really matter where? I suppose if DSD had a high enough sampling rate it might not need a D>A conversion?
cjfrbw
1,355
1,730
Pleasanton, CA
Solypsa
1,811
1,401
275
Seattle
www.solypsa.com
I was more aiming at why not do all processing in the digital domain. More perfect and all that...
Sure some amp topologies more or less become the dac but that wasn't the focus of my question.
rbbert
3,820
239
1,000
Reno, NV
I think the only "processing" is the speaker system Xover? One possible disadvantage is that with a digital Xover one's system automatically becomes multi-amped, adding expense and possible complexity (matching amps to drivers, as opposed to matching one amp to the Xover))
Solypsa
1,811
1,401
275
Seattle
www.solypsa.com
High end preamps are costly and would be omitted in this scenario...
Folsom
6,030
1,503
550
Eastern WA
No because both are not true.
I know exactly what you mean but you simply add to confusion for others. You are going to make them seek gear that does the opposite of what you want with totally wrong descriptions.
Here’s a nice way to describe something that is based on what you hear, not ridiculous proclamations of why you hear it... “it really gets out of the way of the music”. It’s pretty simple, some gear makes you listen to the stereo because you hear small information presented in distracting unnatural ways that make you scrutinize the stereo because the slightest of anything can sound wrong. But other gear “gets out if the way of the music” and you just listen to the music. A lot of the gear that gets out of the way doesn’t always measure like a champ - it’s an easier approach. But also some does measure pretty well but to get that sounding good is a whole other ballgame.
morricab
9,533
5,071
1,228
Switzerland
meaningless gobbledygook. Have you been secretly reading TAS again??
Folsom
6,030
1,503
550
Eastern WA
Never have. I looked at their big list of albums for recommendations on classical once. A few times I've skipped to the end to find a price on a review.
But I find it amusing you call what I'm posting gobbledygook since you use words you claim have dictionary definitions they don't.
morricab
9,533
5,071
1,228
Switzerland
Oh but I have never done that and it is provable, which makes what you are saying fake news, Folsom. Perhaps you are a prisoner of your own mind?
tima
5,870
6,946
1,400
the Upper Midwest
I've used phrases such as: When listening, I like gear that doesn't make me think about it.
You still need to describe what you hear.
Alrainbow
3,260
1,431
450
Organic orange cannot taste as good as inorganic orange that uses my nutritional program sir. :D As far as orange concern, I have never tasted a good orange in US. They are too sour for my preference. From the way and style you described sound, you are a romantic Mike. You should like Mandarin orange. There is sweetness to it.
Paul’s next firmware update will fix the organic orange taste so all oranges will taste equally bad so no one cares
Alrainbow
3,260
1,431
450
Paul is simply saying we should refer to both analog and digital in terms of real. Currently the practice is, when we say it sounds analog, we actually mean it sounds real, and if in the same context we say it sounds digital, we mean it sounds artificial. Paul is saying this creates a sense of discrimination and bias against digital.
Paul makes a fine product for its price point
But to be honest a cheap used TT would show how far off his stuff is. his point is make one feel better in that his digital is close enough. so it’s an Orange rhat matters less as I see it.
Reactions: morricab
AWZ1979
49
21
15
44
I definitely hear a difference between analog and digital. Night and day. I prefer the analog sound. That’s not to say digital sounds bad. It doesn’t. Analog just seems to provide a warmer, crisper sound in my opinion. That being said I listen to and enjoy both analog and digital.
