Hi, you better ask Transparent this. Their website says 120v....Hi,
Transparent PLUG-IN NETWORK PROTECTOR works only at 110 volts or it has universal voltage ( I am in Italy). Thank You
I haven't tried still points, but I have tried other feet and ultimately preferred a good audio rack. You'll hear the feet, hard to say whether everything is better or not, I'd say this is very system and listener dependent. I don't think there is a definite answer to your question....Is there anybody using stillpoints feets under their Rossini or vivaldi ?
Given your system, you'll hear the benefits of a dCS clock. I'd stick with dCS. I suspect if you're streaming or your digital sources can't be clocked (like your i7/SSD) this could be why your dealer is saying what he's saying. I haven't heard your combo, but in my Vivaldi stack it was amazing how much better a Vivaldi Clock sounded that a Scarlatti Clock on all sources. Clocking in important. Better focus, un-ravels the notes better, resolution. Again all easily heard with your Nagra/Wilson combo.Hi Parsons and all in this thread. I will be receiving my Rossini Next week. Has anyone listened to the Rossini with and without the Clock? I can afford the clock, but the dealer said the difference wasn't huge. I'm interested in peoples listening experience. Also are there any clocks that work better with the Rossini than the matching DCS unit?
Are you still using the Alpha clock cables? My local dealer recommended some $4k cables and that’s nuts for a $7.5k clock. Currently using the dCS forum favorite cables and have tried any audiophile cables yet. Personally the clock hasn’t added much to my system yet. Maybe better clock cables will help?It sounds awesome. More nuance, more depth, more dynamics. Love it, thank you!
Just literally dropped in my brand-new Alpha NR power cables to both devices 20 minutes ago as well now. I expect them to take a few days to break in (probably longer, I know) so hopefully with some days of run-in I should be hearing the benefits of those on top of the clock cable.
As suggested, I think the Dac/Clock combo got smoother ahead of these cable changes just by being on a few days, so really looking forward to hearing these at their best shortly...
Clock cables will help. But not change it from bad to great. What is the rest of your system? I am curious how it's configured and maybe something isn't set right? Accidentally plugged a BNC cable into wrong place? Also, can try removing it after listening for a few days, you may notice your missing something all of a sudden. With my clock, things are better organized, better positioned in space, notice a bit more resolution and music seems to be unraveled better. It's one of those things that isn't spot lit, but once it's gone it's missed.Are you still using the Alpha clock cables? My local dealer recommended some $4k cables and that’s nuts for a $7.5k clock. Currently using the dCS forum favorite cables and have tried any audiophile cables yet. Personally the clock hasn’t added much to my system yet. Maybe better clock cables will help?
Also, on the clock it's important for it to be powered up for a few days and never to be turned off (standby is ok). It takes a bit to come up to temp and perform at it's best.
My current system isn’t revealing enough to tell a difference. I assume... Good thing is I just bought new A5s, a super integrated amp, and a HRS rack to replace my current system. My current speakers aren’t properly set up and my listening position is about four feet too far away. My entire system was just lazily thrown together. Even so the clock is the first upgrade I’ve ever added that I can’t tell if it is positive or negative. I’ve had it over a month and it’s been powered up 99% of that time.
It’s frustrating because dCS could easily include appropriate clock cables with the clock. They should make clock cables to sell because their whole “master clock important” thing really requires the cables don’t get in the way. Certainly they have cables they use to test/design their clocks why don’t they share that info with customers?
After factoring in power cable, bnc cables, rack, and isolation the clock adds about $18k cost to my system or approximately 10%. Not sure I’d have purchased it if I knew this at the time.
To be fair... my 16 year old can always hear the difference the clock makes and she prefers the clock vs no clock. It’s possible my hearing isn’t sensitive enough to detect the change. But... I can hear subtle differences between different interconnects and power cords.
What is most important for the clock? Bnc, power, isolation or ???
The Magico dealer is installing my new A5s in two weeks. I can “kinda” sense some more of that precision in space time. With my different power cables running from free to $1,200 I can hear real differences that I can easily describe. Now I can’t say which one is “better” between the two best power cables I own but they are subtly different. My brain probably isn’t trained to detect the types of changes the clock makes.Strange your 16 yr old can hear it and you can detect other changes like cords and interconnects. The stock dCS clock cables I got were good, just there was better and best. The Cardas clock cables are relatively cheap and very good. As far as more important, I think all of those items, cables, isolation all help. I might rank the clock cable first, power cord 2nd, isolation 3rd, but it's an opinion vs statement of fact.
I would invest in a good speaker set up person on the speakers (you may be getting new speakers if I read another thread correctly). The thing about other changes it's usually around tonality or resolution. The clock is about precision in time and space...so maybe speaker setup could be a factor in your reaction. Again, a guess vs a statement of fact.
Can your dCS dealer help with speaker setup? Curious where you live....
I had them under my Bartok but not under the Rossini. Mine are only the Ultra SS and the bigger ones might work better. I preferred the Bartok without stillpoints mostly because they need to be reset every couple of months and that’s too much hassl.Is there anybody using stillpoints feets under their Rossini or vivaldi ?
