Yet another footer thread. Magico S7: IsoAcoustics GAIA Theis or SPods?
owen lawlor
63
52
1,575
Have some S7s coming and need to make foot/spike decisions. Anyone running big Magicos with IsoAcoustics GAIA? Not sold on the whole footer thing but have it on good word the GAIA works well with Magicos and of course for a lot less than the SPods. Wood flooring and would like to be able to slide them around the floor for optimum placement. A bit concerned about imaging too as the speaker would be about 1 1/2 inch higher on the GAIA TITAN THEIS or GAIA TITAN RHEA which my dealer is recommending. gaia.png
owen lawlor
63
52
1,575
BUMP...anyone? found this last night. WOW
MadFloyd
774
1,700
Mass
Congrats on the S7s, Owen. I have never tried the Gaia's so can't really help there. I do own their component footers but do not like their effect in my system. So based on that, if it were me, I'd go for SPods...
Reactions: exupgh12
Mdp632
431
140
173
I can't personally speak on their GAIA footers.
However, I can speak to the Orea footers, which supposedly share the same technology as the GAIA. Just for a different application.
I went in skeptical but, was SO impressed that later this year I will invest in the GAIA II footers for my speakers.
Furthermore, Magico like Iso-Acoustics also posts measurement and specifications on their technology.
That being, Iso-Acoustics has a patent for their products.
The question, is go with the matching synergy of the Magico footers or try the Iso.
If you are based in the United States, perhaps try the Cable Company and see if they have those GAIAA footers (at that size) in their cable library.
Reactions: owen lawlor
Nemal1
371
219
120
61
I have used Gaia’s under my Sasha 2’s for a while now, also on an upstairs suspended timber floor and were an improvement over the standard Wilson spikes. Cannot comment on Magico, but don’t believe the isolators know what speaker they are supporting haha...
As usual, you may be paying a large premium “for the name”
owen lawlor
63
52
1,575
Thanks Ian. I couldn't help myself after hearing their effect in that video and ordered a set. If they don't work out I'll be ordering either the Center Stage or MPod 8s which are the ones spec'd for S7 at $8400, roughly 4x as expensive. Cheers!
MadFloyd
774
1,700
Mass
Yikes, $8400 is expensive! I have A5s on spikes and recently thought about SPods (APods?) but haven't priced them yet.
Let us know what you think of the Gaia's!
Hear Here
744
460
155
Portsmouth, UK
I have Gaias under my 95 kg Avantgarde speakers and find them a big improvement over ealier spikes and other feet. My floor is oak boards on screed on concrete.
However Gaias are very "sticky" so don't expect to be able to slide your speakers. Ideally you should carefully decide on their placement before fitting them. However there's a trick to moving speakers once fitted with Gaias. Take a look here and go to 3min 50 -
. A 2-person job with your speakers, but easy enough!
Another Gaia tip - don't use either of the supplied nuts to secure the footers to the threads. They are a real fiddle to tighten and are pretty flimsy. Then the trouble is it's unlikely the IsoAcoustic logos will face forward as they should. The clever solution is to use a couple of stainless spring washers in place of the nuts. This allows you to tighten up against a load without reaching a sudden stop. Additionally you save several mm of height too. Here's a suitable M8 washer - https://www.ebay.co.uk/itm/A4-MARIN...885538?hash=item2f414ad2a2:g:li4AAOSwzAxejNB2.
Peter
cjf
454
105
948
Does Magico let you swap the feet on their speakers now?
Some clown at Magico decided to permanently attach the spikes to the S3's out-riggers (At least the MKI's) and they cant be removed without getting mid-evil on them and causing likely damage in the process. I guess in Magico's world everyone has concrete floors...Very aggravating
Anyway, if you can swap the spike nowadays and you have raised wooden floors I'm pretty sure its only going to improve things no matter what brand you pick...IMO. I had to settle on Herbie's Pucks for mine but even they are better than the bare spike was.
BlueFox
1,709
406
405
Love my SPODs on my S5. However, I only compared them to the stock spikes the S5 come with.
owen lawlor
63
52
1,575
Indeed they do. I far preferred the outriggers because (along with the flat top) make it much, much easier to level the speakers. That being said, I'm considering tilting the speakers down by raising the rear isoacoustics feet because they will be raised almost 3 inches and the S7 is already having a higher midrange compared to my previous S5Mk2's.
owen lawlor
63
52
1,575
Peter
Just read your earlier Gaia thread and like the idea of using different washers. I was considering getting some sheets of felt and leaving them under the feet for the time being. Some come with sticky backs which would be cool but that video you linked seems to indicate that they are designed to contact the floor directly. This flies in the face of my nature to ceaselessly tweak and experiment with speaker positioning ;^)
Hear Here
744
460
155
Portsmouth, UK
An alternative to the wavy washers I suggested earlier as replacements for the supplied nuts, you could use M8 neoprene washers. Available on Ebay in black or clear. Both would do what's needed - to have the Gaias firmley done up but still alow adjustment so the logo faces forward as IsoAcoustic recommends.
owen lawlor
63
52
1,575
AHHHHHH... I see what you're recommending, Hear Here. Makes a lot of sense. Will try and find some that fit my 1/2 inch 13 thread size.
rbbert
3,820
239
1,000
Reno, NV
CenterStage?
Gardener
68
32
123
I have S7s Owen , why not try them first with they're original footers ?
I have never found a reason to upgrade . Whatever great speakers
Hear Here
744
460
155
Portsmouth, UK
I used the 1/2"-13 felt washers on my Revels.
That's a third alternative to the rather unsatisfactory skinny nuts that IsoAcoustic supply. All provide a soft landing for the Gaias so they can be screwed against the resistance of spring wavy washers, neoprene washers or felt washers until the logo is facing forwards. And all these alternatives allow a reduced speaker height increase compared with the fiddly nuts.
DeYoung
68
60
155
KY
Congrats on the S7's...'Im enjoying a pair with the Mpods. They do make a dramatic improvement over the stock feet.
Btw ..what color and finish did you decide on?
owen lawlor
63
52
1,575
Hey DeYoung - went with MCoat Black. Fits well in any decor. Wife tends to complain less, then all is good...
