Wow, these look great, Bill!!My new motors are ready for shipping hopefully tomorrow. It took a little extra time as I had some custom thread made on the permendur pole so I can use any manner of phase plug that I make depending which driver I use.
Can I ask, who has made these for you, and what were your specifications for the design of them?
I believe Bill asked if he could have the best, and only the best. And then got the best.
To be fair they are a no holds barred and absolutely sumptuous build. Milling permendur is a pita as is solid billet Armco iron like that. Unfortunately he won’t build any more because it was too much work / hassle with complexity and machining.
They have been made for me by a fabulous Russian engineer that I have come to know. The specs were originally configured / conceived for AER drivers.
I asked for a couple of tweaks including the special permendur pole threaded pole piece to allow me to use any phase plugs of my design. Normally the AER motor poles are flat with no plug. The face plate is also drilled to allow flexibility of frames from various manufacturers.
Bill,
Does he have a website, or is there any information on his work?
Thanks
David
Amazing, you’re really going with the flow on this Bill.To be fair they are a no holds barred and absolutely sumptuous build. Milling permendur is a pita as is solid billet Armco iron like that. Unfortunately he won’t build any more because it was too much work / hassle with complexity and machining.
So, no comparisons......how will we deal with this on WBF?To be fair they are a no holds barred and absolutely sumptuous build. Milling permendur is a pita as is solid billet Armco iron like that. Unfortunately he won’t build any more because it was too much work / hassle with complexity and machining.
There’s much involved!… looks like an adventure just getting it fitted and everything settled in… then exploring the outcomes of varying/fine tuning voltage… is the plan still to use an off the rack lab power supply to explore the effect on the power to the fc initially.
Also is re-fitting with the field coil magnet something that you’d be able to feasibly come back from if you ever wanted to try the stock AER fixed magnet back in again. Just perhaps to re-confirm the differences down the track some time once you’ve got your bearings on the field coil… or do you feel that you just need to move ahead to do the custom psu either way. Just that part will be a story in itself.
You’ve got so many choices, figure it will all unfold for you along the way… this is such a great adventure, thank you… love it!
Ked I hate to tell you but you don’t get to see where you are going to end at the start… it just becomes clear when you realise you’ve already raced past itClear vision of where I am going. The last time I said that I was graduating on campus without any work experience
Anybody here ever listened to Oleg Rullit's Super Aeros?
And regarding field coils, let's not forget ESD Acoustics from China.
I simply avoided Lowthers as i found them too shouty and when you see their breakup in the highs it is easy to know why. The only way i heard them work was with the whizzet removed as in Horning speakers, which I like. I am not sure how AER managed to avoid this without resorting to multiple whizzers like Cube Audio but their measurements suggest they figured it out. Voxativ seems to have at least partially overcome this as well. That said, i haven't heard a single driver whose treble i could live with. I hear some breakup on all of them (even the AERs I have heard at shows). Based on comments about your system, perhaps you have done something that could convince otherwise...Hi Graham,
I am fairly laid back on such matters.
I had been looking for field coil motors of good quality and suitable for Lowther for at least 4 years now. I never managed to find any that suited what I was after so when this opportunity came along I didn’t even think twice especially since they were developed alongside AER frames.
I am not sure what experience you have with full range drivers but buying vintage Lowthers and others one has to be pretty well versed in removing the frames, cleaning the air gaps, and realignment. It is part of the journey when one acquires them because invariably the gap will have picked up some detritus on the way. It is quite fiddly and needs a very think spanner to get adequate room to manoeuvre the bolts. I learnt all this stuff about 4 years back and feel very comfortable with it all now. As such refitting the permanent magnets is no problem for me.
On the power supply you got it - plan is to use variable lab power supply in order to measure, listen and land on where I enjoy the drivers most in my system. I will then make something much more “special“ as the final supply.
I am glad that you and some others take a modicum of vicarious pleasure in my mad adventures. Certainly I find it great fun. As I said elsewhere - this is an itch I had to scratch. The best way to learn about such matters properly is to get stuck in with them at home and get involved.
Best.
J
Just talked to him on the phone.
