Im looking for an FPB600 CX to play around with so can add more to the convo then ..
Fantastic...great amp! I remember the Apogee Stages and still consider hearing them a seminal experience, truly one of the groundbreaking moments for me of all the various auditions I have done over the years.Hi every one I have a been using Scintillas for quite a long time now, the first ones I had I used a Krell KSA250 I bought these from the original owner who had owned them from the early 90's he had new ribbons in the Scintillas and the Krell recapped they sounded great, the Krell could power them to very high levels with ease. I now have a pair of fully refurbished/ modified Scintillas running them with a Gryphon Mephisto stereo power amp, this does get hot but even when listening for a good few hours at silly volume levels the Gryphon just plays with speakers it really is a great combination.
Looking at the specs and having heard them a while back maybe I should consider the Mephisto Monoblocs if I won the lotto!!Iv'e had the Mephisto around 3 years maybe 4, I had the Gryphon Antillion before that and quite a few Krells before that. I am a big fan of the earlier Krell amps I had two KSA 80 bi amped, a KSA 250 then a pair of FPB 750 mcx and the best pair of all were my Krell KAS 4 box monos, but the Gryphon is just in another league to anything Iv'e had before
Hi Simon,Apogee Scintilla - List of Krell Amplifiers that can drive them
Krell KSA50 (Just)
KSA100,
KMA100,
KMA200,
KRS-100
KRS-200
Krell KSA 80 (Just with protection setting adjustment)
KMA 160,
KSA200,
KMA 400
KSA150,
KSA250,
MDA 300,
MDS 500
Krell Audio Standard (KAS)
Possible KSA100s
Possible KSA200s
KSA300s
FPBs possibly?
Evolution series a Possibly?
I am going to investigate the suitability of the following to drive a 1 ohm load
Krell FPB 750mcx and Krell Evolution 900
For my 700cx replacement, I may be considering
Krell KRS-200 too old? serviceable?
Krell KMA400 these run very hot so I question longevity and serviceability
Krell MDA500 again these run hot and question longevity and serviceability
I am most likely to consider the last two amplifiers mentioned above and below, as they are the most recent, and probably superior in audio performance.
Consideration will also be given to them provided they can drive the 1 ohm load of the Apogee Scintilla.
I have specified this parameter, just in case I decide to scratch the itch I have had since the late 1980s (teenage!!) to try out a pair of these loudspeakers in my main system.
Krell FPB750mcx or Krell Evolution 900
Simon
Hi Simon,
I've had the KSA-100 Mk1 and Mk2 versions, KMA-100 Mk2, KMA-200 Mk2 and now the Krell KRS-100.
I can't say much about the other models you've mentioned but from the KSA-250/150 series onwards none of them are real fixed bias Class A amps. Friends of mine operated KMA-160's and a FPB-600 which became very hot to the touch.
The KSA-80/200 and their mono derivates the KMA-160/400 all had problems with too much heat and too little heatsinks.
My Krell KRS-100's use much bigger heatsinks (and six of them per channel instad of three) than the KSA-80/200 for instance and with 600 Watts AC intake they keep relatively "cool" compared to the other two mentioned. The KSA-250 was throttled down with the quiescent current and got even smaller heatsinks that fitted in with the width of the frontplate.
It's my belief that only the Krell KRS series of amplifiers are truly Class A (I measured 180 Watts Class A @ 8 Ohms for my samples) amplifiers that can power those 1 Ohm Apogees like the Fullrange and Scintilla.
The longtime importer of Krell electronics in the Benelux (Belgium, Netherlands and Luxemburg) told me that they had lots of problems with the KSA and KMA from the eighties and early nineties and not with the KRS Series other than replacing old caps (especially the deep red radial Roedersteins and relays). No reliability problems as with the other Krells.
I love them because they sound so wonderful!View attachment 76029
Hi Robert,Hi Simon,
The KRS-200 & 100 do probably run equally hot but as stated their coolingcapacity is enormous especially compared with the deratives the KSA-80/200 amps that are clearly under dimensioned.
The KRS-100 is the better amp of the two ergonomically (you can just handle them at your own with 59 kilograms) and the chassisintegrity is better due to the shorter depth. As said I measured 180 Watts of pure Class A @ 8 Ohms which is great.
Of course you can run the Apogee The Apogee and Scintilla directly as a Mark Levinson ML-2 and the Classe Audio DR-3's can by the way.
See the as super ML-2's (which I had twice also) they will drive anything and it was the best solidstate I had.
They cost a nickle to run of course....
KMA-200 was the amp the Dutch importer switched on with the end of a broomstick just in case it would explode...
Not kidding that's what he said but I had no problems with my KMA-200 Mk-2's though and liked them too on my Acoustat 2 + 2's.
I would advice you to go for a pair of KRS-100's and a good service adress.
Kind Regards,
Robert
KRS Balanced plus KRS-200 in Madrid: https://comoficho.com/for-sale/krell-krs-balanced-krell-krs-200_25326Hi Robert,
Thank you for your reply and the information.
Certainly plenty for me to ponder but this confirms what I wanted to do just after selling my FPB700cx. Probably a couple of years off when I will be in a position to be able to start looking for a pair of KRS-200 or 100 amps.
Thanks again
Simon
The price is on the right side...KRS Balanced plus KRS-200 in Madrid: https://comoficho.com/for-sale/krell-krs-balanced-krell-krs-200_25326
Do not know if it is real or what the price is.
You really think 7k will put your house plans in serious distress?Looks like it, shame these have come up now and not in a couple of years time.
My Wife and I are prioritising a house purchase in the next 2 years or so, after then I can begin my search.
Hi Simon,You really think 7k will put your house plans in serious distress?
Such a chance might never again pop up
I have no idea if this ad is legit but if you are looking for those amps for such a long time and the price seems very tempting, I would definitely investigate further
