So I'm using balanced ICs. You think I should wrap both of them in a small loop around the PC?
My first thought is no.
My second is, try moving the IC's around. I've solved problems by actually twisting the ic's around the power cords ( although my example of 125 foot cords is kinda extreme).. Think of the IC's and power cords as defining a loop in space, and that any magnetic fields in the area that are able to go through that loop can make noise. If you reduce that physical loop size, you reduce the amount of magnetic field that can go through it.
Almost everybody I hear tends to say that power cords and IC's don't mix, keep em apart, keep em 90 degrees... None of that is correct... another windmill for me to tip at...
Cheers, jn
Interesting.My listening experience obviously doesn't jive with yours. It's so apparent when an AC cord runs parallel to a PC in my system--sometimes so much that I have to check that my cats haven't moved my cords (that's by laying on them ). Anyway, the most apparent sonic artifact is a brightness and silverly sheen to the sound when AC cords and ICs are in the immediate vicinity.
edit: not a small loop..wrapped the entire length.
Yes, it is certainly worth a try. Even balanced can have the problem, this is generically a pin 1 problem.
But first, just try proximity to. If that reduces the hum/buzz at all, then that would seem to indicate strongly that it's ground loop pickup.
If that does indeed work, then it would probably "behoove" Ray to give me a call. (I love that word..behoove.. It behooves me.. ).. ..
I have tests which will force that issue, so that the designer can fix it out, make the amp bulletproof.
Cheers, jn
We-are trying to bust some hum and buzz. What's your suggestion Myles?
Interesting.
Balanced, unbalanced, shielded, twisted, q's?
Simple proximity of two twisted pairs where there is an integral relationship between twist pitches can easily couple more. When I twisted my ic's around my power cord, I made very certain that the twist pitch of the power cord was not duplicated by my twisting the ic's.
Two cables with either the same pitch, or an integral number will couple strongly in proximity. If the ic's for example, twist at twice per foot and the line cord once per foot, they will couple strongly.
Cat5e cable kills this coupling by virtue of 4 different twist pitches internally.
My point to mep is that if movement of one cord in relation to another causes a system change, then that is a strong indicator that the system has coupling between external magnetic fields and the input circuitry. In your case, it would seem that the power drawn is coupling to the input circuitry.
Cheers, jn
Why no. I have a dedicated 20A circuit for the KSA-250.
I tried moving the ICs around and the hum level doesn't change. I'm sure the hum/buzz is originating from the power transformer as you can plainly hear it when you get your ear next to the top of the amp. I tried wrapping the left channel IC around the PC and that made no difference either.
Devert-No, I didn't try that as I thought that would blow the entire reason/concept of having a dedicated 20A circuit for the KSA-250 which Krell strongly recommends.
http://sound.westhost.com/articles/xfmr-dc.htm ...What makes transformers buzz mechanically? I've always been curious about that
It is worth trying Mark to see if it makes a difference.
