Peter is this the one David and Tang are using?
Very nice comparison this frenchmen did .
This unit measures very good , quit surprising 700 Hz - 6 khz Flat
I dont know how your speaker measures but i suppose its something similar as the Vitavox S2 / Stereolab SL 600 combo regarding High Freq extension , so may be it wouldn t be a bad idea to add a high freq unit
For example a + - 102 db spec View attachment 107798View attachment 107799
I think if i ever was going to do something with Horns it ll be a 2 way system with either the TAD 4001 or TAD 2002 compression drivers , well made with extremely nice flat FR up to 20 khz
The TD-4001 is of the rear compression design, which eliminates the resonance and phase distortion produced by a surround. It also eliminates cavity resonance interference, achieving very flat frequency response, extremely natural sound and superb definition. A phasing plug helps smooth the response of extra high frequencies.
PRO-HF-UNITS — TAD LABORATORIES
www.technicalaudiodevices.com
Andro, I do not know the compression driver or horn that David and Tang have in their speakers. Contact ddk and ask.
my speakers go to about 15,000 Hz. I have not measured them in the room. I do not want to add a high frequency tweeter for extension. I have spoken to people who feel strongly that that would ruin the design of my speaker. They’re just the way I want them. If I had heard issues I would not have bought them.
I think if i ever was going to do something with Horns it ll be a 2 way system with either...
I’m presuming the ‘fourth way’ being active sub base ?Regarding the Vitavox S2, I am using two pair in my 6 way horn system. The first is 600Hz - 1kHz in a 250Hx tractrix, second is from 3.2kHz and it rolls off at 12kHz in a 400Hz tractrix. 12kHz and up is handled by a RAAL Lazy Ribbon for which I am considering horn loading.
If you want the best that horns can offer, I would recommend an active system with at least 4 ways. Two way will not cut it...
Not sure I agree with you. It is VERY difficult to get good coherence in a multi-way speaker setup and most fail to some degree or another. There are some examples of two or maybe 3-way horns that sound very good and can give the dynamic expression that people go to horns for.Regarding the Vitavox S2, I am using two pair in my 6 way horn system. The first is 600Hz - 1kHz in a 250Hx tractrix, second is from 3.2kHz and it rolls off at 12kHz in a 400Hz tractrix. 12kHz and up is handled by a RAAL Lazy Ribbon for which I am considering horn loading.
Don't like the sound of plastic diaphragm compression drivers. Ring radiators are better but a good metal dome design to me still sounds the most realistic.Use a dayton h 812 horn with b&c de 250 driver impressive sound for 1"driver crossover point 800hz really flat to 18khzView attachment 107941
Need damping on the back side (blutak)then it is really smooth. From 80hz -1khz use a tone tubby 12" alnico 100db/1 watt. Under 80hz a ripol bass . Ready for party sounds really goodDayton Audio H812 1" Exponential Horn 100x60 2-Bolt kaufen
Bestellen Sie den H812 online bei SoundImports ✓ Versand am selben Tag ✓ Niedrige Versandkostenwww.soundimports.eu
Alnico Red - Tone Tubby
The Original Tone Tubby®, the favorite of Carlos Santana and many others. Rock-solid bottom end, silky rolled-off highs, and midrange that speaks to you. With ample clean headroom and plenty of power, this is a superb all-around speaker. 50 watt Listen to Red Alnico Speaker...www.tonetubby.com
Everyone has their preferences, you don't have to copy them. I just wanted to show that there are other ways than Tad. too expensive for me for what they deliver.Don't like the sound of plastic diaphragm compression drivers. Ring radiators are better but a good metal dome design to me still sounds the most realistic.
The 4001 lowest crossover point is 600 Hz and the 2002 lowest crossover point is 800 Hz. My crossover is at 500. I would think 500 is better in a two way design, asking the woofer not to go as high. More range for the human voice. Just a guess. Perhaps it doesn’t make such a difference, but I would think for a two-way design, the crossover point would be critical.
what do you think?
The horn sizes themselves provide a barrier to getting a reasonable time alignment on the speaker...not talking actual time coherence but something that sounds reasonably coherent...Thats were measuring comes in .
Just stacking up drivers and adjusting everything by ear is bound to fail.
Thats my opinion
what do you think?
