Ethernet cables
1Biblestudy#
10
1
1
68
I have a dCS Vivaldi Apex dac,upsampler,and Master Clock Transparent XL cabling,with Synergistic Research ethernet switch, currently using Sablon Audio ethernet cables, Sonus Faber Il Cremonese speakers, with Boulder pre and power amps.Anyone with a suggestion on a ethernet cable for me ???
Any cable that passes a Fluke test will be generally fine.
Reactions: MaxwellsEq
I only have short run of CAT8 as I am using F/O and have a very short run from the f/O converter to my Innuos Statement. That being said I am using Supra CAT 8 cables from Madison Sound. I am also using Supra Excalibur USB to my LessLoss Echo's End Reference DAC and I am very pleased with the performance. Have tried the gambit from AQ, Nordost and Cardis. More $$$ will not always mean better performance and sound, IMHO.
I suggest that you put you cable question in the dedicated cable forum below:
https://www.whatsbestforum.com/forums/audio-cable-forum.22/
I think you might get more informed answers from users of different ethernet cables there.
