There is simply no mechanism by which noise can be transferred over an optical cable.
Noise is transferred over electrical connections and no such connection exists using optical. Fiber will kill any noise being transmitted with the data which contains the digitised music.
If this this the case, than the only important ethernet cable would be from FMC to DAC/Streamer - the rest can be "simple" CAT6 U/UTP (see below illustration).
What are you thoughts about that?
Torben
Torben
