...I am about 35 hours in with a new Taiko router, and it sounds *very* nice. Great detail and revealing sonic flow, which I assume comes from an even-cleaner-presentation of the signal.
I am late to add the router to my Taiko switch and DCD grouping, as I have a fiber ISP dedicated to audio, and that already sounded pretty amazing. The Nokia ISP modem is on Uptone JS-2 power, but I removed the Netgear Nighthawk router (was on JS-2) and now it's:
modem=>35' BJC Cat6=>Taiko Router=>Taiko Switch=>Olympus.
DAC cables between router/switch, and into Olympus.
DCD is *currently* fed with a Farad Super3 linear ps. Synology NAS is on the DCD as well.
I have a mix of DC umbilicals in use, Taiko OEM and Uptone Sapphire. A solid-core Mundorf Angelique loaner sounded very nice during demo. Also should note, I was *not* able to get two new shorty Ghent Angelique Stranded/Viborg umbilicals to work in this system, and not for lack of trying.
They seem to fit well into DCD and Router, but not as "positively" into the switch fitting. They do fit as well as some others, but I speculate it is a poor connection with the switch that prevents good contact.
Yes, yes, no silicon spacers added. And three other known-good cables work fine. You can swap them in/out and Roon will connect. FYI. I know others are using these cables/fixtures without issue, but that was not my experience. I won't be doing further testing with them here.
Perhaps I will experiment with swapping the power supplies, but everything is doing so well, I want to just enjoy it.
Lastly, the shipping on the router, for whatever reasons, was protracted. Plan your expectations accordingly.
