Yes, just @tedwoods please provide info about your NAS and power cords of NAS when you will be ready to share your findings.That would be great, I'm sure others too would be interested in the results!
+1At least they could implement regular Phoenix USB.
Interesting @MusicListener .which sounds great but for a little more money and a big increase in SQ power a Pulse mini with a Sean Jacobs mini DC4 ARC6 LPS and output to the Phoenix USB.
Very disappointing indeed.I recently purchased a Pulsar specifically to stream music from my NAS. It is advertised as having the capability to play 24bit/768KHz files for this purpose. Since I use PGGB to upsample my music to this resolution, it was a key selling point. Prior to purchase, I contacted Innuos directly, and they confirmed the ability of the Pulsar to output this resolution.
I have found the Pulsar will not play 24bit/768KHz WAV files created by either PGGB or HQPlayer Pro in standalone mode using the Innuos Sense app. It appears the Pulsar is not capable of playing this resolution except when using a Roon or HQPlayer server with the Pulsar in endpoint mode. This fine point is not clearly stated on the Innuos website, nor was it mentioned in their pre-sale email response to me. If you are someone who listens to upsampled music, be aware of this limitation.
I was able to try the Pulsar in my system for a long weekend. Went with the latter as in my mind the PhoenixUSB was a must have and the SJ DC4 is specd way better than the Pulsar.Interesting @MusicListener .
Did you try and compare for a day? You ended up purchasing the latter?
like this?
USD$ 6899 I tried the Pulsar (w/o Phoenix USB)
vs.
USD$ 1249 Pulse mini
USD$ 5400 with a Sean Jacobs mini DC4 ARC6 LPS
USD$ 3749 and output to the Phoenix USB
USD$ 10.398 + USD$ ?? cables
By the way, SJ DC4 is listed at USD4,000I was able to try the Pulsar in my system for a long weekend. Went with the latter as in my mind the PhoenixUSB was a must have and the SJ DC4 is specd way better than the Pulsar.
Thanks. And nice to be able to compare both at home!By the way, SJ DC4 is listed at USD4,000
Quobuz and files played from a roon NUC server over fibre optic network.Thanks. And nice to be able to compare both at home!
Correct. I mistakenly quoted the standard version arc6 DC4. The difference is now US$2000 (corrected above ;-). That makes more sense.
Did you compare/listen to PULSEmini vs. PULSAR with each streaming from a music service? Or, a likely improvement in SQ : music playing from a dedicated audio server and each in their standalone mode?
Is it possible that the Pulse/mini and Pulsar perform optimally as standalone endpoints in any output mode, while the ZEN/ith series can excel at least at the same SQ level in both standalone and endpoint mode?
Additionally, I'm curious if combining a Phoenix USB with the ZEN/ith series could achieve a performance level similar to their counterparts in the Pulse series, with the exception of the Statement (with or without arc upgrade), which is expected to remain the best performer among them all.
images: melius.club/topic/9553-innuos-pulse-series
What I was describing as a “mess“ was the sound from the Phoenix Lite (reclocked DAC output)Hi Vangelis, maybe I am understanding something wrong in your post. At the start you mention that adding the Phoenix USB 'makes a mess of the music.' Then after you mention that for the best sound, you still need to have the Phoenix in the chain?
I also have a Zenith MkII SE. Would you say that I would be better off getting a PhoenixUSB than replacing the Zenith SE with the Pulsar? Strictly in terms of SQ.This my experience regarding the Pulsar. The Pulsar sounds good. Does it sound better than my old limited edition $7K Zenth MKII? The Pulsar is a bit bolder, with more meat on the bones and authority. That being said, I was given the impression last fall that the onboard Phoenix light within the Pulsar should provide most of the benefit that already existed from my PhoenixUSB and that I wouldn't likely need to continue to keep my PhoenixUSB. There was speculation that adding the Phoenix USB, to the output of the Phoenix light, would actually make it sound worse, and this turned out to be correct, the Phoenix lite output the PhoenixUSB just makes a mess of the music. In A/B comparison between the outputs PhoenixUSB and Phoenix light, the difference was immediately obvious. Unfortunately, the PhoenixUSB continues to absolutely required to realize the best Innuos sound, at least from my Pulsar and Zenith Special Edition. The presentation from the PhoenixUSB is still way more compelling than Phoenix lite, with a greater rhythmic pace, clarity and an unwrapping of the harmonics that just makes the music more understandable and engaging. I was really hoping to simplify my front end, and ditch my PhoenixUSB, the second USB cable and a power cord, the dollar math is not very attractive.
I have the same question and I understand:I also have a Zenith MkII SE. Would you say that I would be better off getting a PhoenixUSB than replacing the Zenith SE with the Pulsar? Strictly in terms of SQ.
So based upon above, it seems to me, for best SQ your MKII SE will benefit more with a PhoenixUSB added compared to a Pulsar without. Fortunately that seems a more economical solution in your situation.Unfortunately, the PhoenixUSB continues to absolutely required to realize the best Innuos sound, at least from my (editPulsar and)Zenith Special Edition.
Interestingly, I didn't find changing the power cable on the PhoenixUSB made a big difference but good USB cables are very impactful.I have the same question and I understand:
It seems you also have to take in consideration if you play local files/from a NAS vs. streaming, and possibly a better AC cable/fuse/USB cable for the PhoenixUSB. Any suggestions someone maybe?
excellent information!I have the same question and I understand:
just added;
The potential vulnerabilities of the present-day Zeniths (around 2016-17) lie in their operating system situated on outdated SSDs (as opposed to the SLC Apacer industrial SSD utilized in Pulsar), as well as the relatively inferior quality of the RAM—lacking wide temperature/industrial specifications. Additionally, the older motherboard generates more heat and noise. I'm curious about the Pulsar's RAM capacity and its placement.
That being said, the energy-efficient 2023 Pulsar outperforms in terms of a higher quality power supply unit, regulators, and inductors (resulting in a blacker background/instrument separation). It employs a single LPS for USB compared to the PhoenixUSB's two, which likely contributes to the observed differences in sound quality. It's worth noting that the current USB output can be substituted in the future to accommodate alternative outputs. Considering these factors, it wouldn't be surprising to see an increase in positive Pulsar reviews this year.
Regarding sound quality (SQ), I anticipate further reviews. Nuno suggests that the Pulsar's SQ should be 10%-20% lower than that of an Innuos Statement, which is a rather bold assertion taking it's price point in consideration (even more so when SQ is closer to 90% of a Statement).excellent information!
Pulsar Upgrade
Pros: newer hardware tech, longer time before obsolescence
Cons: minimal SQ increase
Adding PhoenixUSB
Pros: increased SQ
Cons: additional box, power chord, usb chord, sticking with older streamer/server tech.
those are definitely some bold claims! When the time comes, I will have to get the Pulsar in house and a/b as I use the MkII SE in standalone mode primarily.Regarding sound quality (SQ), I anticipate further reviews. Nuno suggests that the Pulsar's SQ should be 10%-20% lower than that of an Innuos Statement, which is a rather bold assertion taking it's price point in consideration (even more so when SQ is closer to 90% of a Statement).
Also, before judging SQ, take into account your listening preferences:
To me Pulsar seems more geared to internet streaming in Standalone mode and if that's exclusively how you intend to use it maybe even a (mini)Pulse could be sufficient.
- Do you prefer local files or streaming? (The Pulsar lacks a local files option)
- As demonstrated earlier, certain files like PGGB WAV need processing on a main music server before being sent to the Pulsar in Endpoint mode.
- It's worth noting that employing any Innuos device in Standalone mode versus Endpoint mode doesn't produce equivalent sound quality (YMMV of course).
