T Tabl10s Well-Known Member Jul 30, 2019 202 120 148 63 Sacramento Sep 18, 2023 #1 Deleted. Last edited: Sep 19, 2023
Mike Lavigne Member Sponsor & WBF Founding Member Apr 25, 2010 13,799 13,889 4,410 Sep 18, 2023 #2 Tabl10s said: I have the amp at a friend's house and playing with Dynaudio's. He has REL sub's connected that make the amp hum but not when used with his PSA 250. He says the connection is a bi-wired configuration. Any help is appreciated. Click to expand... Maybe clarify the description of the set up. a biwire setup needs 4 channels of amplification. A dart 108 is only 2 channels. detail how the amp(s) are connected to the speakers and how the REL is connected.
A Audio Addict VIP/Donor Mar 20, 2016 153 100 398 Central Illinois Sep 18, 2023 #3 Tabl10s said: I have the amp at a friend's house and playing with Dynaudio's. He has REL sub's connected that make the amp hum but not when used with his PSA 250. He says the connection is a bi-wired configuration. Any help is appreciated. Click to expand... Have you checked your manual. NHB-108 model one Version B - Absolute Sounds https://absolutesounds.com/pdf/main/brochures/358_manual.pdf Is it possible your speakers' impedance is outside the default range? Take a look at sections 4.2 and 5.3 to see if that may help.
