The current being carried would be minute, even with the low DC voltage, so you don't need massive gauge cable, but consider getting a screened cable to be sure that no external interference reaches the TT motor. It's much too heavy but the construction of Belden 19364 is ideal as it has a screen and a drain, as well as 3 main cores. A lighter 2-core cable would be ideal if you can find one.
