Need help with Melco S100 PF clock SJ dc4
b345t
143
64
93
44
So I'm not able to boot my S100 switch properly. Let me explain the story:
I purchased a Sean Jacobs DC4 Arc6 Dual Rail, Melco S100 Pink faun clock upgrade and 2 JSSG360 cables on the used market.
I received the units about 3 weeks ago. On the first day receiving them I tried connecting everything like I was advised to. First to connect the RJ45 coming from the modem into the switch, along with the RJ45 going to my Innuos Zen MK3 server. Then connect the 5v to power the clock, wait 30 seconds, then connect the 12v. I tried many configurations but none booted the switch properly and the light in the front stayed red.
On one of my attempts, I accidentally connected the wrong dc cables into the switch, the 12v in the 5v input and 5v to the 12v input.. I contacted Jord at Pink Faun and he told me to try some things which didn't result in anything and had to ship the switch to him. After checking it out at their premises, he informed me the fuses were blown; so he replaced them and told me everything is good now.
Yesterday I received the switch and have tried many times with pretty much all possible combinations I can think of to boot the switch properly; without any success. So the only thing left I can think of is possibly the 5v power is not working properly? The problem is I can't test that it is functioning; with the 12v I can see the Melco getting power and the back LEDs turn on. Any help would be great right now..
... @b345t it seems (to me) that the PF guys wouldn't have sent it back if it wasn't working correctly. Here is what I would do:
1) disconnect *all* cables from switch.
2) check the fuses. If not ok, replace fuse(s). If ok...
3) power up the 5v clock connection. Let it warm up for about 5 minutes.
4) power up the 12v main board connection.
5) ck power LED indicators, if applicable. Are they good to go?
6) if good, connect network cabling.
It would be helpful if you had even a cheap VOM (Volt Ohm Meter) to check the voltage output of each rail of the power supply, 5 and 12.
Presumably, you sent PF the switch and not the switch *and* your power supply; if so the variable is power at your end. Or a bad connector.
I have not powered up my modded PF Buffalo switch in a long time (it's always on), but when I did, I recall waiting a bit for the clock before connecting the 12v leg. Good Luck!
Reactions: Armsan
Hi thanks for your reply. I don't really know how to check the fuses, they are inside and not the easy type you can just check. I waited 5 mins before connecting the 12v and still nothing. I'll go and get a cheap VOM tomorrow and see maybe its the power supply. I didn't send that over to Pink Faun because its a big and heavy unit..
...oh I get why you wouldn't send the supply, for sure. That VOM would also allow you to check continuity on the connectors, which might end up being a test to try if you don't get the expected voltages output. I guess maybe check output at the supply itself if you find an issue with voltage at the fittings that connect to the switch. I think you already know this, sounds like to me, but I think you are left needing to know:
1) supply rails are good
2) cables are good/bad.
BTW: not sure exactly what connectors you have, but be careful not to short pins if space is tight.
Reactions: b345t
Yes tomorrow things will be clearer. Short pins how? By touching each other?
Did you got it to work?
