Hans Beekhuyzen's latest video explains how he, as a reviewer, will handle that issue. He is purchasing the MU2.A fine review, especially given that reviewers (and most audiophiles) eschew all in one products. Its unlikely that a piece like the MU2 will find a long-term home in Punter’s rotation. There is one glaring omission in the MU2: digital outputs.
Maybe because he has access to the latest Taiko products.Its unlikely that a piece like the MU2 will find a long-term home in Punter’s rotation.
AgreedThere is one glaring omission in the MU2: digital outputs.
It has USB output.A fine review, especially given that reviewers (and most audiophiles) eschew all in one products. Its unlikely that a piece like the MU2 will find a long-term home in Punter’s rotation. There is one glaring omission in the MU2: digital outputs.
Listen guys, I’m a Grimm MU1 early adopter and LOVE the Grimm. The USB output on both the MU1 and MU2 are the equivalent of those found on the least capable computer found at Best Buy. Its a weakness and if Hans B is going to use it to review digital gear, discount the validity of those reviews.It has USB output.
Yeah, Hans is using a USB decrapifier.Listen guys, I’m a Grimm MU1 early adopter and LOVE the Grimm. The USB output on both the MU1 and MU2 are the equivalent of those found on the least capable computer found at Best Buy. Its a weakness and if Hans B is going to use it to review digital gear, discount the validity of those reviews.
do you think it likely that he didn't test the USB option before purchasing the MU2?Listen guys, I’m a Grimm MU1 early adopter and LOVE the Grimm. The USB output on both the MU1 and MU2 are the equivalent of those found on the least capable computer found at Best Buy. Its a weakness and if Hans B is going to use it to review digital gear, discount the validity of those reviews.
From the MU2 manual:It has USB output.
no heartburn, just a difference of opinion (not mine since I have never used USB).I’m not trying to cause anyone heartburn, but the USB port on the MU1 is unsuitable IMO to stream from. USB “decrappifiers” do a decent job and depending on the level of a system, that may be fine for some. One of the things that drew me to the MU1 was an optimized digital stream without the need for all the bandaids and spaghetti nest of LPS/filters et al. If the USB port on the MU2 is similar to that found on the MU1, then it is what it is. I may still be a buyer of a MU2, I just need to experience in my system. Presently, my MU1 feeding a DCS dac is preety hard to beat in my imperfect setup. YMMV But having lived long term in the past with Uptone ether regen/USB regen types of products…I’ll pass trying to optimize USB and stick with AES or ethernet.
check out HB's video about the MU2. He explains at the end how he will use the USB.From the MU2 manual:
This general purpose USB type A connector can be used
to connect an external USB drive (flash drive, SSD or
HDD) to the MU2 system.
Sorry, didn't find anything you mentioned. He says the USB could be used for an USB DAC but it would be better to use it for an external USB drive like described in the manual.check out HB's video about the MU2. He explains at the end how he will use the USB.
Wait what?! You're now saying it does have USB out?Sorry, didn't find anything you mentioned. He says the USB could be used for an USB DAC but it would be better to use it for an external USB drive like described in the manual.
The USB from the MU2 goes to a Singer SU6 USB interface which has 6 different outputs: "The SU-6 digital interface is a new generation of high-performance USB digital audio interface. It uses XMOS' latest xCORE-200 series and Xilinx's high-performance large-scale PGA chip. The SU-6 is a digital interface using a thermostat-level clock system. Crystek's two CCHD-957 femtosecond crystal oscillators provide a solid foundation for the superior audio signal quality of the SU-6 output. The SU-6 digital interface uses a standard USB2.0 input interface, while the SU-6 has a rich output interface, including S/PDI for fiber/coaxial RCA and BNC outputs, AES/EBU for XLR balanced output, RJ45 and HDMI interfaces. Output I2S (including DSD ON signal), clock output supports MCLK main clock and WCLK word clock. "Sorry, didn't find anything you mentioned. He says the USB could be used for an USB DAC but it would be better to use it for an external USB drive like described in the manual.
HB did say that in his YT of the MU2.Wait what?! You're now saying it does have USB out?
Agree,But Hans B using the USB port out of a Grimm to evaluate anything in the future wont inform any gear decision I might contemplate.
