Hydra Typhon T2
Aha, makes sense.
I also tried a low cost Class D amp (in a subwoofer) and it sounded better in the Denali vs the T2. I think mainly because it affected the DarTZeel connected to the T2.
I am still not fully clear on what the differences are between connecting a component to the Denali (that is connected to the T2 via an umbilical) vs directly to the T2?
The shortest path through to the wall is likely the best path for achieving the best DTCD. Plugging amps into the Denali forces the current to have to travel through the umbilical and then through the power cord connecting the T2 to the wall. Plugging the amp into the T2 shortens the path.
Grant from Shunyata mentioned to me that DTCD is more important to the performance of an amp than is noise reduction. So I suspect plugging the amp into the T2 might actually give up a little bit in terms if noise reduction to the amp in favor of better DTCD. The other thing that Grant mentioned was that power amps dump a lot of noise onto the AC, so maybe plugging an amp into the T2 also keeps noise exiting the amp from entering the source components plugged into the Denali.
Excellent explanation, thank you! Better than Richard‘s from Shunyata (although he is great).
This could explain why plugging a cheap (switching power supply) class D amp into the 2nd outlet of the T2 (next to the DarTZeel 108), degraded the sound from the ‘Zeel somewhat (even L-R balance was a bit off).
While Shunyata says that each outlet is isolated, they also say that it’s best to connect one components to one AC duplex in the Denali (i.e., if you only connect 3 components total), indicating that the outlets are not perfectly isolated.
I also imagine DTCD is diminished on a per amp basis if you connect 2 amps to the T2 vs just 1 amp. What do you think?
That conversation with Grant that I mentioned was around the topic of a second dedicated circuit for amps. He thought that in some cases this could be more beneficial that running the amp directly into a Denali v1. His argument had to with two 20 amp circuits supplying a system affords that system greater current capability than a single 20 amp circuit so some amps could greatly benefit from that. I think that goes hand in hand with what you were saying about two amps into a T2 vs one. There would be less DTCD available to them.
What do you think about the best way to segment components with the Denali, if there are more than 3. Does it matter which pairs of components share a duplex outlet?
I know Shunyata recommends to connect all digital components on one Denali and all analog on another Denali (ideally). But in my case they are all analog.
Everything matters, as you know. The nice thing though about Shunyata, is that components to component noise is something they go out of their way to address. I believe there are c2c filters between duplexes and between outlets on the Denali v2 (the v1 only has it between duplexes). Also, if you use their NR power cords, these also contain c2c filters. Regardless, I’d still try to separate noisy components from those more sensitive to noise - even when dealing with analog. Like maybe not having a phono stage share a duplex with something noisy.
Reactions: DetroitVinylRob
Thank you, great advice!
Reactions: kennyb123
I am still not fully clear on what the differences are between connecting a component to the Denali (that is connected to the T2 via an umbilical) vs directly to the T2? I imagine the “supercharging” effect that Shunyata mentions is from the Denali outlets, since those have the dual benefit of the T2 + Denali. But Shunyata still advises to connect an amp into the T2 directly.
kennyb123 has it right
This is how I think of it: The Denali is primarily a power distributor. The T2 is a power conditioner with 2 outlets.
The original Typhon had considerably more of the ferroelectric material in larger NICs than the original Triton distributor and I believe that is the case today with the T2 and Denali. While the Denali includes NICs, connecting it with a T2 brings the benefits of the T2's larger capacity NICs to the six Denali outlets.
By adding two high-current outlets to the T2, it is now ideal for supplying the NIC technology (high-frequency noise reduction) to amplifiers, without requiring the amps to go through a distributor, a more direct path. This is ideal for the setup where the amps are by the speakers with front-end components on a separate rack. Alternatively, if your front-end consists of two components, say a CD player and a linestage, you don't need 6 outlets. Also if expenses are limited, you can buy a Denali for your front-end and then add the T2 later.
The "supercharging effect" mentioned is not a specific technology but the sum of the Shunyata technologies, ie what results from using either product separately or together.
I’ve probably mentioned this before somewhere here but, funny enough, I really like the sound of my MA-1 OTL mono blocks plugged into a Denali V2 as opposed to being plugged directly into the wall. And these certainly draw a fair bit of current. The result is noticeably better micro dynamics and a sweeter micro detailed presentation with the lowered noise floor. This Denali V2 also has four field-coil power supplies feed from it, and is ground wire connected to my (second) Denali V2 feeding the front end of the kit. Both Denali plug into the main with Alpha V2 cables. The overall performance is unmistakably elevated by these Shunyata devices, mains cables, and grounding scheme. I’d be curious how a T2 would be integrated into this arrangement and of course, the possible sonic benefits.
Generally speaking, a Class D amp will not draw as much current as a Class A or B, is that correct?
Did you end up trying a T2 in your system? If so, curious of any impressions. I'm thinking of purchasing one, but am on the fence.
I'm using (3)T2 30 amp version and reference umbilicals on all my amplifiers (1) per with great results
In my system I am using the Denali V2T for front components, clocks, switch, digital preamp.
Typhon T2 is powering the three active fronts, using a reference umbilical to the center active speaker. Sigma XC to wall.
So in regards to comparison to a "normal" layout would be Denali V2T for frontend and Typhon T2 for Amps. This works absolutely wonderfully!
If you want to bolster this setup further you could put a second Typhon T2 powering the Denali for frontend.
Reactions: theclipper
Yes, I recently acquired a T2 and reference umbilical cord on the resale market. I have about forty hours on it, placed to support my four field-coil PS and the OTL mono-blocks. Many in the community have remarked that the T2 seems to not always be the obvious grand-slam that much of SR’s products truly are. I’m currently waiting to offer it enough burn-in/settling time before I make any realistic judgements. I can say so far, it is not creating an immediate positive, order of magnitude performance improvement (or much of anything diff) that was most apparent when bringing the Denali v2’s in the kit presented. That does not mean that I am not hopeful and open minded about the possibilities. Emagine I might always wonder if a T30 may have offered more with these rather deep current hungry MA-1s, but the availability and cost seem excessive to me. Always looking for a cost/performance sweet spot. I believe it needs some time in the kit yet and then the acid test!! Pull it out of the system and experience what is lacking in juxtaposition… if any. Sorry I can’t offer a solid review for you. More later.
Yes, I recently acquired a T2 and reference umbilical cord on the resale market. I have about forty hours on it, placed to support my four field-coil PS and the OTL mono-blocks. Many in the community have remarked that the T2 seems to not always be the obvious grand-slam that much of SR’s products truly are. I’m currently waiting to offer it enough burn-in/settling time before I make any realistic judgements. I can say so far, it is not creating an immediate positive order of magnitude in performance improvement ( or much of anything) that was most apparent bringing the Denali v2’s into the kit presented. That does not mean that I am not hopeful and open minded about the possibilities. I imagine I might always wonder if a T30 may have offered more with these rather large MA-1s, but the availability and cost seem excessive to me. Always looking for a cost/performance sweet spot. I believe it needs some time in the kit yet and then the acid test!! Pull it out of the system and experience what is lacking in juxtaposition… if any. Sorry I can’t offer a solid review for you. More later.
I don't find the T2 underwhelming at all, but there is a big caveat: Just like the Everest, it really needs the Omega XC cable to do its thing. Otherwise, can sound a bit soft and underpowered IMO. With just the Denali alone you don't need that much current, but adding the T2 (or switching to Everest) it does seem like a bigger hose is needed. And then things become much tighter and clearer. Settling/burn-in, does make a difference, though.
Considering the cost of the Omega, it is a bummer realizing the cost of investment was potentially twice what you thought! But the whole system together is impressive.
Yeah, I’m running Alpha v2’s to each Denali v2 as Caelin had commented at one point that they were SR’s best cost/performance hitter. And the sound is magnificent overall. Running old CX Anaconda’s to the mono-blocks and Venom v14 NR’s to the four smallish SS PS’s. Always liked the tone that the CX’s have with the OTLs. I’ll look into your recommendation to what’s best.
Ian B, In regards to your finding that stacked Typhon T2 + Denali V2 works best with Omega XC.
I also think that if you are starting a system, separating Amps on the Typhon T2 with Sigma XC and frontend with Sigma XC Denali V2 on two separate 20A/16A circuits could also be beneficial if you have that option.
Thank you for your response, it's always refreshing to read an honest take. I'm still trying to figure out how I want to allocate my limited resources.
