Subwoofers Compared
Soyez le bienvenu a WBF!
For the same total cost, two smaller subwoofers are often better than on large one, if sound quality is what matters most. Let me explain:
The biggest problem for a subwoofer is the room. The room will cause large peaks and dips in the response of even the best subwoofer. You can move the subwoofer or move your listening chair and the peak-and-dip pattern will change, but it will not go away. You can equalize the subwoofer so that its response is smooth in the microphone location, but then the frequency response will actually be worse elsewhere in the room.
However if you add a second subwoofer, and place it in a very different location from the first, you can make a big improvement. Each subwoofer will still produce an ugly peak-and-dip pattern, but they will be DIFFERENT from each other. The SUM of these two different ugly peak-and-dip patterns will typically be almost twice as smooth as either one alone. And this improved smoothness holds up throughout the room.
Smooth bass is fast bass, because it is the peaks which make bass sound fat and slow. And as a general rule, the more subwoofers intelligently distributed around the room, the more smooth the in-room bass will be.
(I manufacture a subwoofer system that uses four small subs, so I use this idea in my business. I learned it from Earl Geddes.)
So assuming you don't need super-loud and super-deep bass (which are things that one big sub does better than two small ones), you might consider two small subs for better room interaction, because better room interaction results in better bass quality.
A mon avis.
RE: The SUM of these two different ugly peak-and-dip patterns will typically be almost twice as smooth as either one alone. And this improved smoothness holds up throughout the room.
I'm going to have to take issue with theories over substance as I see it (no offense intended).
The way I see it "the SUM" of these two peeks is processed via a pair of ears and a human brain, and not on a mathematical calculation worksheet and or computer software. Yes I believe in science, but also believe science is always self-correcting it's self in pursuit of the truth.
The human brain is going to sense these two sources, sense the confusion they present and reject the inauthenticity of the source(s) - in my opinion.
I looked up the KEF Kube and it also doesn't have variable phase control.
On the B&W PV1D. This is in a totally different price point at about $2k. You could get two Rhythmik F12's (with the Aluminum driver) for this price. I looked at the manual for the PV1D and it does seem to have all of the controls necessary. These all seem to be setup in some kind of software on your laptop. I don't know if you could have your laptop conntected and change the settings real time while you listen. If that appeals to you then you could also look SVS Subwoofers which has an app for your phone that you can control from the listening chair.
The other thing is "space". The PV1D is very compact. I don't know how much space you have in the listening area. So perhaps you are looking for something compact. Also, I don't know what you are intention is. If you are wanting extension down to 20Hz I don't think a single PV1D is going to do that. If you are just wanting to supplement the bass from, let's say, 40Hz to 70Hz.
Note that the higher you go in frequency the hard it is to get he subs to integrate with the main speakers. <40Hz is relatively easy, 40-60 Hz getting harder, 60-80Hz Hard to do seamlessly. If you add a crossover to your mains like the JL CR1 it will make integrating them much easier.
Interesting, I recently did an image search on tube/cylindrical and spherical shaped subwoofers and discovered this unit (PV1D).
https://www.crutchfield.com/S-RNqHysUbpvw/p_749PV1DMB/Bowers-Wilkins-PV1D-Matte-Black.html?XVINQ=GZ0&XVVer=17TH&awcr=628585365749&awdv=c&awnw=g&awug=9016859&awkw=pla-776252067049&awmt=&awat=pla&gad_source=1&gclid=EAIaIQobChMI7dX7ttTJhwMVykb_AR2xFwVPEAQYBiABEgL9D_D_BwE
Two woofers are better than one​
The PV1D is outfitted with not one, but two 8" woofers, which are powered by a built-in 400-watt amp. The cones fire in opposite directions, giving you evenly distributed bass that will fill your room.
Dual drivers firing in opposite directions is similar to my old M&K, and even though it is dual driver it loads the room more like a single point source without the timing errors and phase issues of multiple subwoofer placements.
No way would I spend that kind of money without listening to it first. Back when I purchased my M&K it sounded more musical than a twice as expensive and twice as powerful servo controlled subwoofer in the same room.
Don't get fooled by bombastic power and slam, there is delicacy and nuance in the lower frequencies that some subwoofers are cable of flushing out and not washing over.
I can't agree with the statement, "The SUM of these two different ugly peak-and-dip patterns will typically be almost twice as smooth as either one alone. " as that's not my experience setting up subs many times over, as room dimensions and objects type / positioning throughout rooms are extremely variable. Is there some benefit, yes. Twice?, Rarely.
However, 2 subs do offer the benefit of being able to further tailor the LF response at your sweet spot versus 1, this is a fact. 3 and 4 subs are even better. Also, if integrated properly (not always a trivial task) the ear - brain can't tell the difference especially if you keep the XO frequencies < 80Hz and the slope high, =~24DB / octave.
Reactions: Lagonda
We are all entitled to our opinions
I suggest you read this. I use combinations of single, double, 4 subs. Once set-up correctly you can't hear any of them in any configuration. You are after all in a room and room modes are the dominating feature not the subs.
Rob :)
  • multsubs_0.pdf
Reactions: rob
Rob :)
Thanks Rob, I will look at it later.
Can you tell me if the analysis and conclusions are based on a single listener position, or a wider multi person area?
Hard to tell from the first paragraph where it is headed.
I was only interested in the single person listening position FYI.
I do not have guest over very often, and when I do I give them the good chair.
Both as well as comparing predictions in Mathlab to actual results set-up in real room. Worth a look
Rob :)
Reactions: kach22i
Is there a formula that states one subwoofer for every person in the room?
That really sounds like where "sbo6" and "Robh3606" are headed, intentionally or unintentionally.
There is only one sweetspot in the room with Martin Logans (in general), and I listen alone. I'm just fine with one subwoofer. Sometimes less is more.
The room dimensions the speaker and chosen listening position all are factors to determine what you get. There are no absolute rules and I have never heard of 1 per person. You may get lucky and end up with a spot wide enough to get a couple of chairs with a single sub. That said it is more likely it will be easier using more than one. Hence the multiple suggestion.
With multiple positions I would be way more concerned about the mains set-up and how large their sweet spot is. That above all is going to dictate how feasible it is.
Rob :)
Rob :)
Thank you for the clarification.
I have to think you are right, that with multiple listening locations, multiple subwoofer could be beneficial.
That is unless the entire room is designed as a horn speaker or something crazy like that.
One of the potential downsides in my small room of having the single subwoofer proud of the main speakers is that the single listening position is "near-field" for the bass notes (long waves hardly have time to form), but midfield for the mids and upper frequencies. Is that a potential problem or benefit? Hey it works for me.
I don't recall if I had to flip the phase, but did experiment with it in earlier layouts as I recall.
To be clear, I have not bought a bunch of subwoofers and equipment to find out other options because I got to audio nirvana with the single sub. If you click on my system link in my signature you will see getting a single sub to work before giving up and throwing money at the problem was my goal - and I won.
There is not, and that's not how it works. That would imply that 1 sub could fully optimize LF at the sweet spot, which IME is impossible, unless you have a very large and well - acoustically dimensioned room, which pretty much no one does (and even then subs have other benefits). And in that case, you might not need a sub at all if your goal is smoothing out LF modes.
Now, that doesn't mean 1 sub is not better than none. I'd be happy to share graphs before and after.
At 20 Hz the wavelength is >50 feet and at 40Hz >25 feet.
The ears are a half a foot away from each other, so it is effectively the same as a single ear in terms of locating the sound.
In one of your earlier posts you mentioned that the sub was only encoded in Mono.
That it sort of at odds with the brain processing 2 sub sources, and also at odds with your single sub approach.
If the response in the room is relatively flat, then one can argue that enough subs are being used.
At bass frequencies, where the ear's time-domain resolution is poor, my understanding is that the in-room frequency response dominates our perception. I'm not saying it's the only thing that matters; I'm saying it's what makes the biggest difference.
My understanding is that the ear/brain system is incapable of separating the multiple bass waves which sum at the listening location, much less discerning whether those combining bass waves originated from different bass sources (different subwoofers).
Imo reasonable minds can disagree, so I'm not expecting you to agree with me.
Reactions: Robh3606
What factual proof do you have to substantiate how the human brain functions and your resultant opinion? Neuroscience studies? Other related medical documentation?
@kach22i, here is the full context of one of my statements that you singled out ("The SUM of these two different ugly peak-and-dip patterns will typically be almost twice as smooth as either one alone"):
"However if you add a second subwoofer, and place it in a very different location from the first, you can make a big improvement. Each subwoofer will still produce an ugly peak-and-dip pattern, but they will be DIFFERENT from each other. The SUM of these two different ugly peak-and-dip patterns will typically be almost twice as smooth as either one alone. And this improved smoothness holds up throughout the room."
The critical stipulation is that the second subwoofer be placed in a VERY DIFFERENT LOCATION from the first. The MORE acoustically similar the two subwoofer locations are, the LESS smoothing will be produced by their summation.
And I probably should have said, "The SUM of these two different ugly peak-and-dip patterns can be almost twice as smooth as either one alone."
I am a recent convert for using subs with stereo speakers. I’ve used subs (Linn Melodiks, Klimax 345, and JL Audio Gotham v2 and Fathom 113v2), for many years for LFE in a theater but never integrated with stereo speakers. I have now purchased and integrated a six pack of REL No 25s.
I posted this graph in another thread and thought it was fitting for here. While measurements don’t tell the whole story (this is the first I have ever measured), I purchased a Umik1 and installed REW out of curiosity.
This is of the front left and right speakers with integrated REL six pack. The RELs are behind and slightly outside of the main speakers. The microphone is at the sitting position around 13ft from speakers.
The graph surprised me, especially below 20hz and down to 2hz (although I assume there is some error at these frequencies),
My ears are the final judge, and they like the music and movies they are hearing. While I am still tweaking it sounds more like live music than ever.
For movies, I do still have a JLA F113v2 integrated with center channel, and a F113v2 and Gotham v2 for LFE (the RELs are also fed an LFE signal).
The room is acoustically treated with numerous bass traps.
Reactions: Tlay
If you swap the Rels for the JLAs you might be surprised. ;-)
This topic has been discussed many times in many forums over the years, and for what ever reasons it can get heated unnecessarily.
I don't have time to argue or sell anyone on a philosophy, but I have found when doing a search on the topic today a poster in another forum that gets what I get. That said, some people's brains and ears are going to hear things differently than others, no changing that.
Look for posts and images by "MSchu18", he says it better than I can anyway. I am not part of that forum and don't know the guy, but we seem to be from the same school of thought.
Reactions: Duke LeJeune
I don't think you and I will have any trouble keeping our conversations civil and respectful. And if you do see me crossing the line, please call me out on it!
Thank you for that link, it was very helpful in understanding your perspective. I think there may be a misconception which hopefully I have not contributed to:
A distributed multi-sub system DOES NOT cancel modes! (There IS a technique that cancels modes, but this isn't it.)
And, imo, modes are not the enemy! It is the relative scarcity of modes in the bass region that causes the major peaks and dips in the frequency response of most rooms which stick out like sore thumbs, and which a distributed multi-sub system seeks to address. This is somewhat counter-intuitive, so let me start out higher up the spectrum:
If you look at an ungated and unsmoothed in-room frequency response measurement, in the midrange and high frequency region the measurement itself looks like grass. There are so many peaks and dips from the in-room reflections that they run together like a field of uncut grass, and effectively form a continuum. They are so numerous and close together that the ear/brain system does not hear them as separate events.
The lower we go in frequency, the further apart and therefore the more potentially audibly distinct the individual peaks and dips become. Somewhere in the 150-250 Hz ballpark (it varies from room to room), these room-induced peaks and dips become perceptually dominant, and this is what we call the "modal region". The larger the room, the lower the frequency at which the room-interaction peaks and dips become dominant.
If the room is large enough, like a concert hall, it has SO MANY modes in the bass region, and they are SO CLOSE TOGETHER, that the in-room measurement still looks like uncut grass, with the reflections effectively forming a continuum, just like what happens at midrange and treble frequencies in a small room. This is a primary reason why bass instruments sound so much better in a concert hall.
With an intelligently-distributed multisub system the net result is a much denser in-room peak-and-dip pattern, which approximates the in-room bass behavior of a much larger room. The semi-random-phase summation of multiple different peak-and-dip patterns reduces the relative size and spacing of individual peaks and dips. No we don't get the "grass", the "continuum" that happens further up the spectrum, but we do get an arguably useful improvement.
Here is acoustician Matthew Poes comparing a distributed multi-sub system to bass trapping in the subwoofer region (south of 80 Hz). This was recprded years before he became a dealer and started selling speakers. He gets his point across in about 30 seconds from where the clip is cued up to:
So a distributed multi-sub system is not canceling out room modes; rather, it is approximating the greater modal density of a larger room.
That is an interesting piece of information, thanks. However, I'm not sure I agree, but I very well may be wrong to be fair. Here are my thoughts based on my experience.
Yes, I agree, mid and high frequency reflections are many and our ear - brain expect that and make sense of that information (within reason) depending on the direct sound amplitude versus reflected sound amplitude and decay. However, for lower frequencies, we hear differently, and as such, I'm not sure the same analogy applies whereby emulating mid / HF delay (e.g. comb filtering) = the same experience with multiple subs in our small rooms.
Also, for your multi - sub system, if the goal is not to reduce peaks / dips, then what is the recommended setup (phase, amplitude, xo freq, etc)? What does "good" look like in a FR graph with a multi - sub versus without the subs? I ask because I have 4 subs and I target achieving a house curve that suits my listening taste while keeping the decay (especially in low frequencies) as managed as possible for best sonics.
Thanks in advance for your feedback.
... for lower frequencies, we hear differently, and as such, I'm not sure the same analogy applies whereby emulating mid / HF delay (e.g. comb filtering) = the same experience with multiple subs in our small rooms.
I agree, what's happening at mid and high frequencies does not translate directly to low frequencies, because, as you say, "for lower frequencies, we hear differently."
It takes at least one wavelength before we even begin to register bass energy, and multiple wavelengths before we begin to register pitch. Given that bass wavelengths are longer than the reflection paths in our rooms, we cannot perceptually separate the "direct sound" in the bass region from the later-arriving reflected sound, at least in the size rooms we have for home audio. The good news is, this means that in-room bass measurements are reliable predictors of perception, unlike in-room measurements further up the frequency range.
That being said, the more closely the in-room reflections approach a continuum, the more effectively the ear's critical-band averaging characteristic perceptually smooths out the room-induced peaks and dips.
The idea is to activate so many modes - to generate so many room-interaction peaks and dips by having multiple subs in acoustically very different locations - that we no longer have lone peaks and dips sticking out like sore thumbs. If a particular modal peak is only strongly excited by one out of four subs, then instead of that peak sticking out 8 dB above the average, maybe now it only sticks out 2 dB above the average. (The actual interaction between the outputs of the different subs is more complicated than this implies because the reflections are interacting in semi-random phase, which results in a lot of decorrelation in the bass region; the hypothetical in the preceding sentence is just for illustration.)
In practice there is often still some frequency region that rises a few dB above the average. Because the spatial variance is decreased, this issue is probably present throughout the room, rather than being confined to a small area as is typically the case with a single sub. This is beneficial because now EQ can be used to fix the issue WITHOUT the likelihood of simultaneously ruining the frequency response elsewhere in the room.
Here is Earl Geddes, he is the originator of the asymmetrically-distributed multisub paradigm that I subscribe to. I suggest watching at least the first 16 minutes or so:
And Matthew Poes again, cued up to where he describes his version of Earl Geddes' setup approach:
