Marantz 7 clone tape head preamp
adrianywu
712
820
168
58
Viktor Khomenko (Foxbat), founder of Balanced Audio Technologies, has made a series of Youtube videos on this particular preamp. It is based on a PCB sold on Ebay: https://www.ebay.com/itm/3547632385...ar=624092303927&widget_ver=artemis&media=COPY
The Marantz 7 preamp is a full function preamp with phono as well as tape head input. It has several EQ curves for the pre-RIAA phono records, and NAB for tape heads. The phono/tape head section is based on three 12AX7 tubes. It has two amplification stages and a cathode follower output stage. EQ is applied by applying feedback from the Cathode follower output to the cathode of the input stage.
I have previously built a no holds barred balanced differential tape head preamp, with external shunt regulated power supply, for my Nagra T Audio tape machine. I initially had EQs for the two CCIR, NAB and Nagramaster, switched using relays. I have since hard-wired the EQ components for CCIR15 only to avoid switching.
For four track tapes, I have been using a Revox B77 with upgraded output card from Audvance. I am intrigued by the Marantz 7 circuit, as it will give me a more genuine 1960s experience with these four track tapes.
The seller also has a presence on Taobao, the Chinese version of Ali Express, at a slightly cheaper price. I also bought a chassis from Taobao, from a workshop that makes custom chassis but also sells a range of ready made ones in different form factors. The chassis I bought is based on the Kondo M7 phono. I bought a toroidal HT transformer and a filament transformer from another shop. The total cost came to 950 RMB, about US$135, shipping included. I also bought a couple of 6X4 rectifiers, and I already have a stash of 12AX7s (NOS Tesla ECC803S).
Then, it is just simply drilling the holes on the bottom plate to secure the board and the transformers, connecting the power, output and input wiring and making a low resistance chassis ground connection. The chassis comes with two positions on the front plate for rotary switches. I installed an additional power switch in one, and a rotary selector switch in the other in case I want to install addition EQ curves later.
The board comes with RIAA EQ, which I need to modify for NAB. Since the LF pole of the two is the same, I just removed the other components and put in a 7.2K resistor, which together with the pre-existing 6.8nF cap will give the 50us HF turnover.
For the B77, I installed a switch to allow switching between external and internal playback electronics. There is conveniently already a hole on the chassis to the left of the headblock, probably for an optional feature that my machine did not come with. There was just enough space between the chassis and the face plate to accommodate a 4PDT toggle switch. I disconnected the cables from the head and reconnected them to the switch. I simply used a pair of twisted wirewrap wires to connect the head to the switch. I used the Gotham GAC3, my go to cable for my microphones, to connect between the switch and the preamp. A separate ground wire is connected from one of the screws on the headblock directly to the ground post of the preamp. There is an unused hole on the back of the machine, marked slide projector, that is perfect for the exit of the cables. I removed the plastic cover and slid the cables through the hole. At the other end, I connected the shield of each cable to a separate wire ending in a spade to connect to the ground post of the preamp. By separating the shield from the signal wiring, I have the option of connecting the head as a floating source to the balanced input of my other preamp.
Using the MRL calibration tape as reference, the HF is almost spot on, with about 1dB down at 16kHz. The LF was however way off; +6dB at 32Hz and +4dB at 64Hz. Changing the LF resistor from 680K to 300K got me to the ballpark of +1.5dB at 32Hz. I have ordered trim pots to further adjust the response.
I initially connected the signal ground to the power supply ground, but there was a low level hum. After cutting the connection, the preamp became dead quiet.
The connections of the cable shields to signal ground are essential. One connection fell off the ground post and the result was a horrendous noise from that side. The motors in the tape machine generate a lot of stray fields.
Like Foxbat, I was pleasantly surprised by the sound quality of this little preamp. Compared to the solid state Audvance board, which is already a very significant upgrade, the M7 has a richer, more colourful string tone. There is better depth of image, with better separation during busy passages. On the other hand, the internal board seems to have more solid and impactful bass. The preamp output is about 15dB lower than the board.
As it is, the preamp is a very worthwhile upgrade for most tape machines, especially at this price. The components that came with the board are pretty high quality, but there is further room for improvement by upgrading the coupling caps, increasing the value of the PS filter caps (but don't go overboard), and perhaps installing a filter choke for the HT supply.
Many thanks to Viktor for sharing his discovery with everyone. I had a lot of fun putting this little project together.
Hi Adrian great job! I agree with your sound quality improvement impressions.
A couple of points. When you dropped the 680k resistor down to 300K, you also lowered the gain, so consider shunting the 510 Ohm resistor with a 300 Ohm one, like I did. I would then re-evaluate the pole parameters.
On the ground connection…. I have none in my tape deck, and the cable shield is only connected to the preamp input, and there is absolutely no hum this way. There is also no connection between the Marantz board and the chassis, but of course every system is different.
This was a fun side project and since I already have several other preamps I suspect this one is going to see limited use… unfortunately.
One other side projects I am considering is converting one of my balanced preamp’s input to single-ended configuration. I already have one in that topology and I like its sound.
Please post your further impressions.
Victor
Victor
Thanks for the advice !
Victor
I have listened to the new preamp for at least 50 hours now. Interestingly, there is a hum coming from the right channel when the tape machine is in stop, but it disappears immediately when I hit play, and the preamp is very quiet during play. I am still stunned by how transparent it can sound, more so than the upgraded internal electronics. I just listened to the Reiner Nutcracker on RCA (LSC2328 on LP) last night. The Royal Ballet gala performance is the famous RCA ballet recording, but this Nutcracker is equally excellent. The sound is so transparent and detailed that my jaw dropped after just a few seconds of the opening. In general, the RCA tapes from the late 50s and early 60s are excellent. They have low background noise and the recordings are fabulous, and they are generally inexpensive. They preserve the best qualities of Shaded Dog LPs without the distortion that often plague the LPs. Another amazing tape is the "Night on the Bald Mountain and other orchestral showpieces" on London. The recording appeared as "Romantic Russia" on SXL6263 on LP. Again, very low background noise and huge dynamics. I actually have a 1:1 copy of a production master of the same recording, and the four-track is not far behind. The MFSL reissue LP from the 1970s sounds thin and aggressive by comparison. The scale of the presentation through the Marantz 7 clone is huge. Very happy with this very inexpensive component.
Good job! Glad you are enjoying it, and it is always nice to know you don't necessarily have to invest a huge sum in order to get a noticeable improvement.
I'm just a newbie to R2R. I remember the oraginal Marantz 7 or similar models have NAB options for 4 track tape? Can I use them directly? Can 2-track tape be used?
Yes, but most two track tapes produced today employ CCIR equalisation. The oldest commercial tapes produced from 1954 to 1957 were two track with NAB equalisation.
