Tell you what, Tim, I'd take you on as my lawyer any day, to defend me against impossible odds. When you've got your jaws locked onto a bone, absolutely nothing is going to make you let it go! ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Frank
Frank
Frank
I'll tell you what, Frank...you build the 2400 watt super amp and send it to...who's a neutral party here? Mep? he's on the line between subjective and objective? Amir? You choose. They will A/B it, blind if you like, against, in Mep's case the vintage, is it 200 watts, Mark? Phase Linear, or for Amir, a 500 watt ML. If they conclude that your amp even holds its own, I'll set up a webcam and eat my hat, and crow, on the board.
Tim
I'll tell you what, Frank...you build the 2400 watt super amp and send it to...who's a neutral party here? Mep?...he's on the line between subjective and objective...Amir? You choose. They will A/B it, blind if you like, against, in Mep's case the vintage, is it 200 watts, Mark? Phase Linear, or for Amir, a 500 watt ML. If they conclude that your amp even holds its own, I'll set up a webcam and eat my hat, and crow, on the board.
Tim
I kicked off this thread in search of motivation, and as Roger suggested, I now have it in spades ....If they conclude that your amp even holds its own, I'll set up a webcam and eat my hat, and crow, on the board.
Tim
Frank
I agree with everything you and Jack say, in normal situations it is overkill, but there are certain environments where it is almost essential, like driving the MBL 101Es I mentioned earlier. The power ratings you mentioned are what I envisage: the real problem with a lot of higher powered amps is that the power supplies haven't been sorted out as well as they should have, so then you need to jump to an even higher level of power to get them to drive the speakers cleanly. Plus, having such power is obviously a talking point, it makes sure people will check it out ...Frank,
I don't even want to speculate as to the size, weight, and power (electricity consumption) for a 2400 watt amp. Are you suggesting 2400 watts at 8, 4, 2, or 1 ohm? My big Aragon Palladium 1K monoblock amps are 124 watts Class A, or 400 watts Class A/B @ 8 ohms, 600 watt Class A/B @ 4 ohms, and 1000 watts @ 2 ohms. The amp does not not double down like a lot of the bigger Krell or Levinson amps, but in most instances it is more than sufficient for most speakers. As Jack has suggested 200 watts solid state is more than enough.
Even my 25 watt Class A First Watt M2 Power amp is more than sufficient to drive my 104 or 105 dB/1w/1m OMA New Yorker Prototype speakers at least for my 19'4" W X 14' 7" L X 9' H room to play as loud as I could stand. I know that Tom Danley may disagree on that, but...
Rich
One thing Tim finds so hard to fathom with regard to the HT setup is that I can run it at level 40 out of 40, maximum, but then wind it back to 20 and the sound stays the same, subjectively it doesn't really appear to have got that much softer but obviously the power drive is dramatically lower. This is the sort of behaviour a good system should be capable of, to get realistic reproduction.
Frank
It is impossible the sound can "stay the same" from when you have the volume control maxed out and turn it back to half way. This simply means that your volume control is stuck at full-on or you have a severe hearing problem. I see no other explanation other than a vivid imagination.
That underlined is the key here. I'm sure the 101Es will humble most amps out there with ease, but attach some 106dB sensitivity speakers to just about anything and you should be able to deafen people! My first serious DIY used Goodman's Axioms, with that sensitivity, and a silly, single transistor DIY effort from a popular electronics mag. And it did nice sound too ...I don't think it's possible to clip a well designed powerful amp with well matched speakers, I have never clipped my amps. Of course I don't turn the volume up to obscene levels either. The one thing that I enjoy about lots of power is the effortless ability to reproduce the dynamics in the recording. I love the rush,when the music just soars. Now maybe 20 watts will get the job done,but you won't convince me to change from 1200 watts.
I can feel your pain from here, Jack ...You guys know I try to be painfully polite but even if Frank's electrical magic worked there is still no way it would sound the same, the room would overload acoustically. It just isn't possible.
Now this is interesting ...In a word.....Yes. It happens in Jazz clubs all the time my friend. Heck it even happens in the mall food court at lunch time and that's just people going about their business.
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
