I bought everything from Taobao, the Chinese equivalent of AliExpress. The seller of the board is also active on Ebay. https://www.ebay.com/itm/3532273047...uid=k1rzcijyqes&widget_ver=artemis&media=COPY
There are manufacturers of PCBs, chassis, transformers etc. on Taobao that can do custom orders. Only 2 to 3 days turnaround. Very convenient. I spent about US$150 for the whole thing.
Have to turn this thread over to diyaudio.com
Yes, this is all textbook stuff. I wonder if it has occurred to you that your claims apply to transistors too, even opamps, yet somehow they can get some pretty decent numbers out of them (which suggests that something else is afoot...). How much schooling are you asking for here? Do you want me to walk you through it?Well, like I said, it is all text book stuff, anyone can find it, I am surprised anyone would struggle with it. "Works quite well" is not a technical term.
BTW - I would like to see some proof of that totally improbable number of 90dB CMRR in a tube circuit. That number is several orders of magnitude higher, than is achievable, so some proof would be nice.
OK: a bit of schooling. There is a simple way to get around the need for high ultra high precision resistors. FWIW, such resistors would be needed for a solid state circuit too so this is not a tube or transistor thing, its a good practice for differential amplifiers.One great mind once wrote here:
"tubes benefit from that with regard to CMRR so that value can be decent- well into the 90dB region."
It clearly says: TUBES. There is absolutely no way under the Sun that the tubes can get even close to it. The discussion had to do with tube amplifiers.
For those not familiar with the situation (back to the same textbook stuff again), in order for a circuit to get 90dB of CMRR it must use the resistors with .001% tolerance. When was last time anyone purchased those?
That if you disregard the contribution of active components. Just the basics.
So I would be extremely impressed if a tube differential amplifier had anything higher than, say, 10dB.
Hm. It seems as if you ignored most of my last post.That is why I wrote:
"That if you disregard the contribution of active components."
I am still waiting for some proof of a tube circuit with 90db CMRR.
Do you have it?
As I stated earlier, the CMRR in tube is pitiful at best.
Not a problem... I will sit back and wait for you to provide the CMRR measurements of your circuit, and also the noise calculation, showing the balanced stage superiority.
