Hi guys. I need advice and am hoping some of you are enough into robotics, remote control gear to guide me in the right direction.
Need to have a flat platform that can with precision go forward and back a few feet. Precision requirement is to one inch accuracy. The platform needs to be able to carry up to 100 pounds. Speed is not critical. Need something as simple as this that would be able to be told to move forward and back with precision:
Movement will only be forward and back. Does not need to turn.
I am hoping there is a motor, gear reduction and controller available that I can use to build this. Alternatively if it is already built, that would be great.
Need it for an idea related to audio if you can believe it .
Tried researching servo/stepper motors and such and did not get anywhere quick. Appreciate any help.
