The amps with the lower THD and SNR are usually not the best sounding.
If you chase the specs, you are often doing so at the expense of sound quality. Usually, it's because you have feedback loops (like global negative feedback) that end up doing more harm than good. Look at DarTZeel's specs, they are terrible - comparatively. You can argue specs all you want over at Audio Science Review
en.wikipedia.org
"This fact forms the basis for the weighting curve shown here. The weighting curve is misleading, inasmuch as it presumes inaudibility of flutters above 200 Hz, when actually faster flutters are quite damaging to the sound. A flutter of 200 Hz at a level of -50db will create 0.3% intermodulation distortion, which would be considered unacceptable in a preamp or amplifier."
"Ideally, flutter should be measured using a pre-recorded tone free from flutter. Record-replay flutter will then be around twice as high as pre-recorded, because worst case variations will add during recording and playback. When a recording is played back on the same machine it was made on, a very slow change from low to high flutter will often be observed, because any cyclic flutter caused by
capstan rotation may go from adding to cancelling as the tape slips slightly out of synchronism. A good technique is to stop the tape from time to time and start it again. This will often result in different readings as the correlation between record and playback flutter shifts. On well maintained, precise machines, it may be difficult to procure a reference tape with higher tolerances."
So the measurement is essentially meaningless if you try to compare from one machine to another.
