I get the point but I hope your significant other never reads it.
P you should put your poetic skills to better use ..like ..writing poems
I have decided to embrace the future and am looking for better reproduction in my home... It means better attention to the fundamentals, Room Acoustics comes first,
So subjective is okay now. Nice, at least we are starting to have some common ground now P in that what we choose is what we like more because of what we hear and not just by what's been measured.![]()
I'm fine with the subjective if the analog absolutists can get past making statements ripe with implications of objective superiority. Or I'm fine with data. Show me the data. Show me vinyl's superior measurements.
.. True that.. You guys are making my ..very slowwwwww day ...
P you should put your poetic skills to better use ..like ..writing poems![]()
Jack
Any reproductive process is flawed because ..well.. it is designed by humans ... The better processes are less flawed .. Let's take aside R2R for now ... Vinyl is an extraordinary flawed process.. It is a miracle it manages to sound that "well" at times... The first brutality is the RIAA pre-emphasis.. cut the low boost the highs and this is not linear as there are some "crossover" points ... then you have to do this in reverse with an analog circuit that now cut the highs and boost the lows .. a recipe for more problem since now you are also amplifying ambient noises aka foot falls , the bass from the speakers, etc ... Let's not talk about the cutting lathe or the amplifier used to drive these and the formulation, etc... Noise shaping is benign in comparison...
The crux of the matter is: Do we like to hear things as close as possible to the way they are or are we (some of us anyway) more comfortable with the "familiar"?
You are making me cringe JackDo you mean zero crossover points Frantz? Digital has this between every single plus to minus and minus to plus transition. This is exactly what noise shaping attempts to address. Analog has it based on transistor switching. So digital gets it not just during the process but post conversion as well.
What you are describing is dither. And as non-intuitive as it sounds, the science shows that dither fully eliminates quantization noise from digital samples. Yes, it is noise. But that noise has magical characteristics in how it takes harmonic distortion created due to discreet samples and turns it into benign noise. Not a perfect analogy but bias signal is used in R2R to deal with the limitations of that medium.I fail to see how noise shaping in the form of inserting random information via algorithms can be better than altering the levels of the signal via EQ when the former alters the signal itself.
You are giving me ideas for a number of articles I need to write about these topics to bring better clarity .
P.....i'm not touching your post.
objectivity. it requires exposure to evidence. you need to be open minded to what any format can do. that takes investment in time, gear, and software to get the experience for yourself.
you gotta listen.
my path in this hobby has been defined somewhat by investigation of all formats.
in 1995 i got back into vinyl to see if it was as good as Fremer said it was.
in 2000 i got deeply into SACD to see if that might be better than vinyl.
in 2005 i added multichannel SACD to my 2-channel room.
in 2007 i dived into RTR big time....also got into the vintage tt's.
in 2008 i added a music server and later hirez downloads.
in the last few months i purchased a mono cartridge and cleaned my 300 mono Lps; i've been investigating how good mono's can sound.
i don't have any agenda other than listening to music in the best possible format.
so no; it's not about be deluded by anything other than how well the music can communicate. i like all the formats and listen to them all. but when people who have not made the commitment to listening to all the formats make claims based on things other than listening at the best level possible then i'm not too tolerant.
if someone says; i've done this specific listening to this specific gear and this specific software and i drew this conclusion then i'm reading with great interest. but speaking about how something can't be this way because of 'blah, blah, blah' and i'm smarter than you.......please spare me.
Well, Mike, it's good to know where your interests lie. I'll bear that in mind as I compose my posts. My methodologies are a bit different than yours. Your sounds far to time-consuming and expensive when there is still so much great music I haven't heard. Mine is simple: I have my reference systems, and a lot of components have come and gone and have been auditioned in those systems over the years. They almost always came in with a liberal return policy, and the overwhelming majority of them got returned. I listen to new components blind whenever I can figure out a way to do it (headphones present a difficult challenge). That's my criteria for taking user reports seriously; Did you get a friend involved and figure out a way to compare the new component to the reference without knowing which one you were listening to? If you did, then I'll be reading with great interest.
By the way, I don't think I ever said I was smarter than you. It may very well be true, but you are the one who brought it up, not me.
P
P
so now we go from 'digital is better than vinyl but; i have not had any sort of reasonable vinyl reference...ever' to 'blind testing'.
i think this is where I’m outta this thread......or rather; i've played this 'end game' more times than i care to think about and i don't need to do it again.
What's true is most people like digital because it's cheap, easy and requires little effort. Analog is better but requires a hell of a lot of work to make right. Like many things in life the things that are the hardest to achieve are the ones most worth fighting and working for.
How about for What's Best Forum we agree that digital is the best cheap format, provided you don't spend enough to make it a bad investment. Also agree that if you work hard at it the best sound for home is analog, at least among the formats that us mortals can access on our own.
No, we cannot agree to that. We think vinyl is sloppy and distorted, and that the well-mastered Redbook CD is superior. You do not agree. That's the subjective part: Our opinion against yours. The objective part? We win, hands down.
P
Where was it, gentlemen, that I said I had not heard any good vinyl rigs? Or that I chose digital for the convenience only? In debate, these are called straw men. in this old argument, let's just call it changing the subject. Again...if you like the sound and the process that is vinyl and get joy from it, good, good for you. But if you insist that it is better in some substantive way, I disagree, and I'd like to see some substance.
The only other thing going on here is that Mike gave me a detailed description of his method for trying out new gear. I gave mine in return. I'm struggling to understand how that is offensive.
Informal blind listening has served me well, though I know it is no substitute for a controlled ABX test carried to a statistically significant sample. But even in its simplest form, it has helped me to debunk some of my own myths, determine what I hear and don't hear, and identify what is important and needs to be addressed next. It is not much more than listening with your eyes closed, hearing with one very influential distraction removed. Well, except that it sometimes reveals some rather uncomfortable information. I once learned, for example, that there was not a clear difference between 3 dedicated headphone amps, at pretty radically different prices and technologies, and the headphone jack of a digital AV receiver. That was pretty embarrassing, given that I'd spent weeks singing the praises of one of those amps and swearing it squeezed more dynamic range and detail out of my Senns than I'd ever heard before. I tried the test repeatedly. I tried it in short, quick switches and after a week of listening to only one amp. I tried it on friends and relatives. Ah well....
But if you guys don't think it is possible for you to be influenced by expectation bias, I salute your confidence. The mere mention of unsighted listening seems an odd reason to get angry and stomp off, though. Nevertheless...
Enjoy the music.
P
Hi Guys
Debate is healthy but let's forgo some of the innuendo and name calling
Hi Guys
