I have to say, I'm NOT surprised by the results.
Be it violins or stereo components, people can tell what they prefer and you'll get an honest response as long as they cannot see what they are using.
I might just chime in here because I have a background as an audiophile since the early 1970s and having played the violin to A. Mus. A (diploma) level from the early 1980s. Firstly, most professional musicians are not audiophiles. Most of the ones I knew had very basic audio systems. Their focus is a different one to actual sound in terms of pure technical analysis per se. With a professional musician it is all about sound production - that is, employing a technique to get the best out of the instrument you have and the music you are playing. It is a bit hard to explain but with many pro violinists it almost works like a switch. They are happy with a $100 sound system but then they will go to an obsessive degree to get every nuance out of an instrument, fanatically experimenting with bowings and fingerings to get a tiny phrase right. I well remember some lessons where 9/10ths of the movement for that week was despatched in 10 minutes and the final 50 minutes was spent on two bars...
Anyway, I just have to say that at the outset, not everyone has the same level of ability when it comes to distinguishing differences as alluded to by the experiments here. For my own part, I've never had trouble identifying expensive antique instruments from reasonably priced modern ones, though it is true it does not follow the former are better than the latter. Back in the early 1980s I took part in a test - over the radio using a Sony desktop mono FM receiver - where the listeners had to pick between a Strad, Del Gesu, Vuillaume and a modern instrument. I picked all four of them with ease, even with the massive handicap of listening over FM radio using a battery powered Sony radio. I also just did that test at the Daily Telegraph link above and got three out of three for that as well - on my laptop via $50 earbuds. Mind you, the violin playing was abysmal in that link - absolutely horrid, so it is not a good test.
Another critical thing to understand too is that a lot of what makes an instrument feel "good" and "expensive" has absolutely zero to do with the instrument itself. It is instead all about the quality of the bow and the setup of the instrument. By setup, I mean bridge size, bridge curvature, distance between the strings, neck angle, the nut (the piece of ebony at the pegbox end of the fingerboard that supports the strong tension), distance between the strings and the fingerboard, the fingerboard curvature, fingerboard wear, ease of string tuning, peg fit, peg movement, sound post tension and sound post position, string type and string gauge. Well those are the main things I look for anyway.
Suffice to say I would rather play a well setup $500 violin with a $5,000 bow than I would a $4 million Del Gesu poorly setup with a $500 bow. And I'd make a better sound with the cheap violin too.
And the final thing. It is acknowledged amongst top professional string players that the player is largely responsible for the actual quality and aesthetic appeal of the sound anyway. My teacher always used to say that David Oistrakh would sound good regardless of what violin he played. Well, the analogy here is with audio equipment versus records / CD, what have you. Most of us agree that the quality of the actual recordings are at least as important - if not more so - than anything else so long as you are already at a decent quality level equipment and setup-wise, and it is the same here. So long as you have a half-decent violin, it is you the player, the bow and the setup that are more important than the instrument, even though the instrument obviously has importance too. But it is not as important as the player in terms of what is required to make a good sound (by that I mean giving an illusion that the violin is great whereas it infact might be modest but the player is excellent). And that is a fact.
I have played a number of expensive Italian violins and yes, they are great but often you can actually get a more pleasing sound from a $10,000 old German violin that is the violin equivalent of a vinyl setup running with single-ended triode amplification. Or you can get a great modern violin that is the equivalent of an incisive and precise NAIM setup. We pick our hifi poison and picking our favourite violins is no different.
I have played a $120,000 violin that I thought sounded like crap. I have played a $5,000 violin that I could happily play the rest of my life and never want anything more. One thing I do agree with - the best Strads and Del Gesus are not worth remotely the money they fetch based on sound alone. It is the craftsmanship (at least for Strads!), the fact that they are antique, the provenance, the materials and the aesthetic visual appeal that really fetches the money. You give your $2 million violin to a professional appraiser to value and they don't actually have to play it. They look at it. That is all they need to do. Any playing is only out of interest and to see if there are setup issues (which might cost a few thousand to fix - a miniscule fraction of the value of the instrument).
Final thing: You could carry out a hundred tests where every participant - expert or layman - gets every instrument wrong. It isn't going to make the values of the big name antique Italian instruments budge by as much as one cent. They will just keep going up and up in value regardless. And that is that. End of story.
PS: I made a couple of home recordings myself using a $12,000 violin and a $600 one. If anyone is interested I could load them up and see if people can work out which is which. The bow was the same for each - around $2,000 value at the time.
i have also found this. kind of makes a mockery of us lol. i did have it explained to me why this is the case but iv fogotten. very poor indeed as that bit of useless info could been anything but give this context.
You know, even assuming the instruments are all set up beautifully and they're all being played with the same bow, the selection of a musical instrument, while it is about sound, is largely about the sound of the instrument in the specific musician's hands. That, I think, renders these tests a pretty moot point.
Tim
I don't know exactly when the prices of the great Cremonese violins started to soar - maybe related to the dot com bubble, but reading concert programs, it appears that quite a few violinists of a certain age own Strads or other valuable violins (including members of orchestras or chamber groups and not just the top soloists), while today the great young violinists almost always are playing instruments that have been lent to them, sometimes on a long term basis by very wealthy individuals or organizations.
And to honest, I completely fail to understand it myself too. To me it is one of the greatest contradictions. I was fortunate enough to learn from one of the best (though admittedly my modest talents did not justify it) and sometimes the obsession with sound could drive me to near insanity or at the very least extreme levels of frustration. Think the equivalent of spending a week moving your Tannoy Westminster speakers a couple of cm here and there and for some inexplicable reason still not being happy...that is the sort of frustrating obsession with sound that my teacher (and others of similar ability) were like. Spending an entire lesson just on a few bars and sometimes I myself - despite being an audiophile - could not hear the slightest difference but apparently the teacher is sometimes happy with how I sound and sometimes not. Mind you, a caveat here is there is an analogy with cornering a fighter. The fighter might have all the techniques down pat but they need an external observer to process the fight with an eye to details their fighter cannot process during the moment as an active participant.
Yet my teacher, with all this obsession for actual sound, then happily puts on a dirty LP borrowed from the local library of Yehudi Menuhin playing a Bartok Romanian Dance and it sits on a turntable that in this day and age would be the bastard love child of a Crossley and a base model Project! At least she had an open reel deck! But that was her husband's (who was also a pro musician and probably a bit more audiophile-ish relatively speaking).
That said, there are a couple of current well-known violinists who are audiophiles. Rafael Todes is probably the best known and he writes eloquently for UK publications. I always avidly read his reviews because I have always found - on hearing the equipment he reviews - that we always see eye to eye (or should that be hear ear to ear) and that he is always looking for the same qualities in equipment that I am.
http://www.allegriquartet.org.uk/rafael.html
Ilya Gringolts is another. I am sure I read at some time (possibly not on the net) that he had a top-notch NAIM system, specifically choosing it because like us, he knows good sound when he hears it.
