Aps purepower
Eli08
240
1
Hi there,
Anyone has any experience with the purepower +3000? I am considering it. Have read very good things about it, but also some people seems have had reliability issues in the past.
Thanks
LL21
14,430
2,518
1,448
Hi there,
Thanks
HI...I have not heard it, but have seen on other forums that people who own them love the quality of sound that comes from using it...but BOTH did have serious reliability issues. One got sorted and the other did not and gave up. Both seemed to suggest they knew of others who equally had problems and it was an issue that affected the company's reputation. Hope things work out if you decide to try it. Good luck.
Eli08
240
1
Yes that is very similar to what I have heard. I need some power protection and while at it other features it has sound good. this seems to be a good alternative if it works... That is.
People who have tried it all say it is very good.
