inside the entrance hall to the barn.
musical instruments as art.
i went to a local music store and purchased some used instruments. seemed like an appropriate thing to do. i'm always on the lookout for just the right 'art' thing to replace it but so far i'm happy with it.
I thought this thread was about "Art in the Listening Rooms", not art in the hallway. Shouldn't this be 'functional' art, if it's going in the listening room?
I doubt you would want some big reflective surface in a listening room. It should act as either a bass trap or some sort of diffusor.
Studied under this for two years in Dental School. Landlord's daughter was a high end art dealer in LA, and said I could keep a piece of art. I chose this one since it watched over me for two years, it's been in my listening rooms ever since.
Didn't think the OP was concerned with functionality.
Wouldn't you want whatever you place in your listening room to not have a detrimental effect? Someone that has spent thousands on a room/system to get it to sound good, you certinally wouldn't put something in there that would undermine all your hard work!
If it would otherwise be a bare wall, it probably won't have a detrimental effect.
