Hmm... never chased a greased pig around a county fair,since that's not something we do in Canada (we chase hockey pucks around on a frozen pond, which makes much more sense). Why is the pig greased? And why are you chasing it? Do you have scientific evidence that the pig is greased or did some audio reviewer simply tell you it is greased and you are accepting it based on faith, or because you purchased a pig at great expense advertised as greased, and would be embarrassed to find out that in fact it wasn't greased ??
Sean:
OK. I'll be serious now.
1. If Steve's speakers sound good on many recordings then that is great! That doesn't mean his speakers are necessarily accurate because we don't know for sure the source of the recordings (see circle-of-confusion problem). Comprehensive measurements of his speakers would confirm they are accurate.
2. Dave Wilson's experience you describe above confirms the problems with all listening rooms that I discussed. The loudspeaker and its interaction with the room acoustics is a big problem that needs solving. i agree with you that solutions are at hand, but are not well documented or validated in the scientific literature.
3. Where in my previous post did I say something that would lead you to say: "If you don't think Wilson is neutral". I never even discussed Wilson or the Q5. I think you have mistaken me for another poster.
4. Where in my previous post did I say "you are anti-science"?
5. "You cannot have it both ways. You can't demand that a speaker be properly designed and then wiggle out by saying it does not matter anyway because the room will muck it up"
You have misunderstood what I wrote. The optimal design targets of the loudspeaker DO MATTER and they are clearly defined and remain the same regardless of the room and its influence on the sound.Our loudspeaker design targets are defined and verified based on anechoic measurements that remove the influence of the room. We don't include the influence of the room in the design of the loudspeaker. Why? Because all rooms are different, and you cannot possibly predict the influence the room on the loudspeaker's performance until it's actually installed in the customer's room. I did say that a room will muck up the bass, but how does that constitute "wiggling"?
A well-designed loudspeaker will always sound better in more rooms than a poorly designed one (with or without room correction) because the direct and reflected sounds produced by the speaker will be more neutral as you move around the room. The problem with the room then becomes isolated to mostly low frequencies (< 200-400 Hz) where judicious loudspeaker/listener placement, multiple subwoofers, and room correction solutions can help.
Do you still think I'm "wiggling" and feel like you are chasing a greased pig? Or is that more clearly explained? I hope so because I won't sleep well tonight with the imagery of being a greased pig being chased by you
