Hi folks, my first post as an OP! In the midst of a few "infrastructure upgrades" to our music and cinema room. Replacing the two 15a 12g wire dedicated lines I ran from a busy 100a panel 20+ years ago with three new 20a 10/3 dedicated lines which will only share a new 80amp panel with a new Mitsubishi Mini-split and ERV on the opposite phase. Hey ample quieter power and a new whisper quiet dedicated HVAC system- what's not to like!
Anyway, my favorite contractor understands and humors my audiophillic tendencies and as such all three new dedicated lines measure the same length two within an inch despite dropping at center rear wall, center right wall, and center front wall. They will also feature isolated hospital style grounding. The receptacle safety ground pin is on a separate insulated wire from the exposed ground wire to the box and metal shielding of the combination of "BX" armored shielding and steel surface mount raceway the AC cables run through. The two separate isolated grounds are bonded at the breaker box only. To effect this arrangement I require Hospital grade 20a receptacles with the ground strap isolated from the ground pin. We currently have some orange Pass & Seymour Hospital grade (green triangle) duplex receptacles on hand but I was looking for something better. I've looked through Furutech and Oyaide's online technical docs and found no mention of the isolated grounding feature. Any suggestions???
