Allnic's AUT-8000 Step UP Transformer now with variable impedance loading!
ketcham
216
144
175
ALLNIC’S NEW
AUT-8000 SILVER
MC STEP-UP TRANSFORMER​
Allnic has improved its moving-coil step-up transformers, now available as a separate device that can be used with all Allnic or any other manufacturer’s phono-stages, the AUT-8000 Silver, or as replacement MC transformer towers to upgrade the Allnic H-5500, H-6500 and H-7000 phono-stages (all new production of the flagship H-8000 DHT (Direct-Heated Triode) come with the “silver SUTs” as standard).
Allnic analogue specialist’s H-8000 DHT Phono-stage with Power Supply​
The new, in-house manufactured Allnic MC step-up transformers feature pure silver wire windings on Allnic’s famous permalloy transformer cores. The silver windings provide increased resolution and dynamics, soundstage three-dimensionality and instrument and voice “substance” and “body”. They are truly a “step-up” (apologies) from the standard copper-wound SUTs and will make any Allnic phono-stage preamp provide even more lifelike sound than that for which they have been universally praised by reviewers and users.
The stand-alone AUT-8000 Silver now features variable impedance loading!
The stand-alone AUT-8000 Silver replaces the AUT-2000, which featured copper windings on the transformers, as do all Allnic’s phono-stages (besides the H-8000 DHT) and features not only the silver-wound SUTs but also enhanced flexibility. Only the H-7000 with the Silver SUT option has this flexibility integrated into its circuitry!
The AUT-8000 Silver sports variable impedance loading (the same as on the H-7000/H-7000V phono-stages) and dual MC inputs, allowing the user to connect two tonearms.
The AUT-8000 Silver has a single pair of unbalanced (RCA) output connections and a ground post and comes in the customer’s choice of a rugged silver or black aluminum chassis.
The quality is superb and has me entranced…….dead quiet and to my surprise, fantastic out of the box.
In fact, for a new SUT to sound so perfect is almost weird….
Thank you so much for such a wonderful gift
J.D.L. May, 2023​
Whatever your choice, as a replacement, upgrade SUTs for your current Allnic phono-stage or incorporated into the highly flexible, stand-alone AUT-8000 Silver, Allnic’s new, in-house manufactured silver wire-wound step-up transformers will elevate your vinyl rig to a higher level of performance, proving a “silver-lining” for your system, gracing it with even more clarity and realism, clearing away clouds you may not even have realized were there.
Contact your local Allnic Dealer for further details.
Massimo66
118
126
50
57
1710599426460.jpeg Dear staff, I already own this splendid aut 8000. I would like to know if instead of the 10 kohm resistor it would be possible to replace it with a 75 kohm resistor so as to be able to better adapt the impedance of my My sonic lab sig cartridge. platinum. exactly how my h7000v is set up. thanks for any response
ketcham
216
144
175
Here is a recent favorable review of the H-7000 with the Silver wound permalloy SUT, effectively an integrated AUT-8000
Massimo66
118
126
50
57
Good morning, very kind staff, I read the review carefully but the only point where the word silver was mentioned was when the journalist talked about the color in which the H 7000 can be had. Reading on the allnic website I seemed to understand that yes can order everything wired in silver. another thing that I haven't read until now is how much the silver transformers bring the sound of the 7000 to the 8000 with the necessary differences in terms of dynamics. perhaps you could suggest to the parent company to give a dual fuel option. there we would really be breathing down the 8000's neck. anyway, a 10,000 h has already arrived.
