Steve williams
Good to read that someone agrees with me on directivity. It makes absolutely no sense to me for the prices these fuses cost when Tomelex has explained it perfectly
Myles,Excuse me Steve, price? I think the fuses are a bargain given the results one obtains using them.
Excuse me Steve, price? I think the fuses are a bargain given the results one obtains using them. I can also list a lot of other tweaks that are a lot more expensive and not only don't offer any return, but product negative effects.
And Steve, I'm really surprised by your comments. You should know given the resolution of your system that everything makes a difference; whether or not it's a positive effect is another story.
I also find it interesting that the same thing is happening in the fuse discussion as in the analog, cable, etc forums here. We have people who have not heard the fuses, cables, etc. are offering opinions on why the fuses can't possibly make a difference. It's kinda hard to take those arguments seriously. I've described the effects I heard in two sets of amps; if one listens and doesn't hear a difference one way or the other, then fine. But it seems that myself, Rich, Marty, Albert and Robert are the only people who have actually heard the HiFi Tuning fuses.
For the record, here's the explanation I received from Bernd regarding fuse directivity that weren't included in the review. Pardon Bernd since he's German and writing in English for me:
The explanation, that You can hear a difference in the directivity of fuses,
is related to the dynamic behaviour ( that means, for example the negative
portion of the ac- wave is a bit less attenuated, than the positive half AND
in Your following system (for example transformer)is the opposite
imbalance.) Than You hear a difference.
As usual in audio - sometimes You get the best results, compensating one
tiny error with another tiny error in the opposite direction.
By the way, the same way cables are "directional" . A much higher
"directionality" You´ll find with transformers - it makes a much bigger
difference, to which side phase is connected.
And there other designers out there who have heard difference between the sound of fuses from different manufacturers.
So I suggest Steve that you get a fuse or two and play with it in your LAMM gear; you might find the results surprising given the quality of your system.
And Microstrip, you must have had speakers that were't compatabile with your amp if you kept blowing fuses. I for one know that I couldn't live with a piece of geat that kept blowing fuses. Twice during the same recording?? Something was dead wrong. And this from a SS amp nonetheless.
Steve-Thanks for having an open mind. You can't ask for more than that. The only problem I see with having people over and performing the fuse test is that you will have to power the gear down, switch the fuses, and wait for the gear to come back up to temperature by which time aural memories might fade. Still will be cool to try though. I for one have never tried any of the "super" fuses so I personally have no idea if they make any difference. And Microstrip, you must have had speakers that were't compatabile with your amp if you kept blowing fuses. I for one know that I couldn't live with a piece of geat that kept blowing fuses. Twice during the same recording?? Something was dead wrong. And this from a SS amp nonetheless.
I put the Supreme fuses back for now. After speaking with my rep, he advises some time to let them settle. I just figured that since they underwent a deep freeze, followed by a bolt of lightening for quantum tunneling, they would sound stellar right from the start. So, I'll reserve judgment until next week. Right now, they sound mechanical, raw, and disjointed.
The gold fuses are quite agreeable, and probably where one should start for a demo. I am not going to bias the results by spilling the effect I hear....
Just to be clear tony, I do not believe in directionality of regular fuse or regular interconnect or speaker cable, as long as each end is the same connector, etc.
But I did try in fresh cut two pices silver wiers for making interconnect cable , connected to a small speaker driver, and reverse direction on both, they really sound small difference, may be after break in it changed, and I do believe after break in sound getting better especially tonearm cable, I always use radio line out signal to burn with a 2k resistor for a week of a fresh made before to put it on othorwise it will take too long to be done by the MC cart signal
tony ma
Tony Ma, are you aware of how critical the position of your head is when doing any "comparing tests"?
http://www.ethanwiner.com/believe.html
Tom
When I do the comparing test in my system I will stand and sit all the listening area to check the image still in the same position, I do had critical position problem long time ago before but not now, from that time the system had been change a lot pictures show my set up without serious critical position problem
tony ma
Hi Robert,Update: Supreme fuses are going, gold fuses are staying.
Hi Lawrence, In my system, the Supreme fuses sounded somewhat mechanical and uninvolving. I think this could be a system-dependent issue, because others have found them to sound beneficial. I have not tried the Silver. In my system, the gold seems to add a touch of tonal richness and midrange depth. The Furutech fuses are said to be very good as well, but I am content not to try those.
Sometimes fuses will come on the used market, but with all the different specs, you may need to just buy new and sell yourself if it is not to your liking. That is what I did with the Supreme Hifi. I don't think demos are allowed, even through the Cable Co.
Hi Miles, Yes, I think you are reading something incorrectly.
