Huh? Audio fuses...again???
One would think that everything that can be said about audiiophile fuses has already been said on this thread. But honestly, I have no idea since I’m not planning on reading all 1152 posts. If you’re expecting to find out what the “best” fuse is for you in your system, you won’t find it in this post. Rather, I wanted to share some systemic information that you might find useful if you go down the fuse rabbit hole looking for a fuse that will make your system sing just a bit better.
My recent exploration of fuses started with a casual PM conversation with Mark at Sablon Audio as we discussed what fuse might be nice to try in the Extreme and assorted other gear. He suggested I might try a fuse from Padis, who OEM’s the fuses by Furutech. What Mark said that really prompted my fuse exploration was his analogy that fuses are like spices for food. They can change the flavorings and just like salt, pepper and other condiments and spices, can change the flavor to your liking…or not. I was surprised to look at my Soulution 725 only to see that a Padis fuse was being used there as factory stock. However, since I’m not exactly a fan of rhodium, I thought I might explore some other “flavors” of fuses. This exploration then expanded to the Lampizator as well. The real challenge was to try and figure out if there was some general guidance I could use in choosing a fuse without the need to try every fuse ever made, which would be an impossible task.
Ali Express is kind of like a hardware store for audio stuff. Like a hardware store, you often don’t know you need someting until you walk by it or in the case of Ali Express, until you see the ad for an item. In Ali Express, there’s not a lot of rationale for what get presented to you. However, it's pretty easy to search for audio fuses.
In general however, after searching a dozen or so fuse manufacturers, it’s fairly easy to see that all audiophile fuses have basically the same basic components, and it is these components that might vary among different manufacturers. Learning this now gave me at least some direcit9on for picking a fuse and possibly understand why it might work well (or not) when I tried it in a specific application. This is the information that I hope you might find as useful as I did.
From this pic, you can see there are 5 basic components of a fuse
1) The end caps- they are generally made of tin or copper and may be plated in gold or silver.
2) The caps inside the end caps (that the fuse wire is soldered to). Some brands such as Brimar state they use Mundorf gold and silver solder. Most do not specify their solder material
3) The “pipe”. Most of us are familiar with glass but may many are made of ceramic material.
4) The fuse wire itself. It can be silver, copper , or in some cases, there are dual metals such as silver wrapped in copper wire:
Alternately, hybrid material such as a copper/silver blended wire can be used as the fuse wire (i.e. Brimar) as well as “nanocrystalline alloy”.
You might also see materials listed such as this
"nano-super-high molecular" technology, using long fibers immersed in invisible super-high molecules”.
The scientist in me naturally wondered what “nano-super-high molecular technology” could they possibly be using? Even more puzzling was trying to wonder if invisible molecules are really present, and moreover, if they are “super-high”, what exactly are they high on? Alas, no answers were immediately forthcoming to either query anywhere in the product description. Ah, the wonders of marketing. Who makes these things up? I doubt its anyone from Harvard or Wharton, but I may be wrong! It was obviously another marketing genius who was responsible for bestowing this ridiculous brand name for a fuse manufacturer.
5) The material packed around the fuse wire. This can be a variety of materials from quartz sand, to nanographene to flooby dust or some other strange (proprietary of course) material.
How these materials are packed also varies by manufacturer. Here are two examples.
I should mention that some fuses state they are packed with some type of mineral oil, but I would be very reluctant to try these for an obvious reason. If one of those fuses blew, I don’t want to take a chance that I might have to clean oil out of a fuse holder in an IEC outlet. I’ll stick with the assortment of other solid flooby dust materials, thank you very much.
You may also find some manufacturers cryo process their fuses. It’s also worth pointing out that some manufacturers specify a fuse orientation; others do not.
The take away from this is that you can avoid a lot of confusion if you understand what a fuse is comprised of. If, for example, you found a fuse you wish to try that has silver end caps, silver wire and quarts glass packing, it makes little sense to buy another fuse that is made of the same components. You might want to try one with different features instead. There aren’t that many options to try if you stick to the most common variants, even though the plethora of brand names can be daunting. I suspect that many of these fuses are made by the same manufacturer but are branded with many different labels, most of which I’ve never heard of. So the details of the what a fuse contains is probably more important than any brand of label that you see. I would also add that if a manufacturer did not describe or show me an exploded view of their fuse, I avoided the brand altogether since they provided no useful information that I could use to correlate sound with materials. Some might say that’s not important as its only SQ that counts. And that’s a reasonable approach as well, just not one I was interested in exploring.
Finally, I found one brand of fuses that I found
very interesting.
https://www.aliexpress.us/item/3256803031260117.html?spm=a2g0o.productlist.0.0.75badd8ch3aY8E&algo_pvid=d0500f1a-f709-4399-b03b-2ad8e4c0fb4e&algo_exp_id=d0500f1a-f709-4399-b03b-2ad8e4c0fb4e-1&pdp_ext_f={"sku_id":"12000024707421986"}&pdp_npi=2@dis!USD!40.62!37.78!!!!!@210318bb16722615959166692e1c5e!12000024707421986!sea&curPageLogUid=Q4hbGQzE1Xns
You will note that this manufacturer makes fuses of different colors and these colors are priced differently. Hmmm…this sounds very suspiciously like the famed QSA fuses that have been reviewed elsewhere in this forum. You will recall that the QSA fuses come in different colors as well that are separated by price point. One difference is that the fuses listed above range from sapphire color ($37) to Dragon Red ($554) whereas the QSA fuses range from inexpensive to thousands of dollars! Could the “CreateAudio” fuses in the ad above be the OEM for the QSA fuses? I have no idea and I suspect that it will not be easy to learn the true answer to this question although certain similarities seem like more than coincidence to me. (the different color body at different prices and the use of the much ballyhooed words “quantum and nano” by both manufacturers).
In any event, I’ve been exploring a few of the rather modest cost fuses on Ali Express and have found that indeed I have a preference for some over others in a specific application, but this is still a work in progress. I will share that I did not find a better fuse for the Extreme than the one supplied by Taiko, which I believe is a gold capped ceramic body fuse (not sure of the brand). Happy hunting.
