Republicoftexas69
If it is the same input/output values.Clever idea to burn-in the fuses in a piece of gear that is always on![]()
What did PT Barnum say??????Long story short. You can’t plug in a brand new fuse in expectation it sounds perfect from the first hour. Most fuses need +\- 200 - 300 hours to burn in. In this time it’s possible that the system sounds crap for a few hours/days… I mostly let them bake in the PSU from my modem or switch which are on 24/7. After around two weeks I swap it into the component for which I bought it… If you don’t hear any improvement you either bought the wrong fuse or you’re deaf![]()
Which power cords and signal cables are you using?Like I said had them in for well past the return window, had well over 600 hours on them and notta, same as having a stock ceramic furse. Rather spend the money on treatments, tubes, cables..... at least that particular brand.
LessLoss Classic power the classic with Firewall 640x , Zavfino Silver Dart Graphene IC XLR and SE. goal is to transition to all LessLoss IC‘s after I sell down my cable collection.Which power cords and signal cables are you using?
The QSA process appears to be a burn-in process. There is a video of it on YouTube. The different prices allegedly reflect the length of the process. So having to burn in a product that you are effectively paying for burn in doesn't make any sense to me.Long story short. You can’t plug in a brand new fuse in expectation it sounds perfect from the first hour. Most fuses need +\- 200 - 300 hours to burn in. In this time it’s possible that the system sounds crap for a few hours/days… I mostly let them bake in the PSU from my modem or switch which are on 24/7. After around two weeks I swap it into the component for which I bought it… If you don’t hear any improvement you either bought the wrong fuse or you’re deaf![]()
The reason why regulated safety fuses have to be mass-produced is because they have to be made to consistent and extremely tight tolerances that cannot be done, for example, by hand-made production. One issue is solder time because, obviously, fuse wire does not like heat. Littelfuse specify less than 5 seconds (ideally 2 seconds) with a low temperature limit (150c). The fuses are tested straight off the production line.
Having never heard a difference with any fuse, audiophile or otherwise, I must be stone deaf. I do wonder if psychologically it's possible to wait 200-300 hours and then not hear a difference! I was persuaded by a friend to get a few Analogue Productions and a Cohearent vinyl from the USA, I just got them today, took 3 weeks, if they don't knock it out of the park I will be extremely disappointed.
Let you know how the SDFB works when I get back in town next week, have one coming for one of my tube integrateds. Off the fuse merry-go-round for me. Have had great results with their Puron product in my audio chain. Also much more economical and like the idea of a magnetic CB as that can be reset rather than a spending $600.00 USD on a fuse.View attachment 120578
I mounted another two SR Masters right now. There’s an improvement from the 1st second, but what I hear now is by far not the full potential of this fuse. It will definitely sound way better after a ~200-300 hr burn in period.
No idea why you didn’t hear any improvement from any fuse![]()
The QSA process doesn‘t aim to burn anything in the way running current through it would. That should be obvious by the long burn in times reported combined with what’s said about the sound quality once it gets through that. No amount of burn in could achieve what the QSA process achieves.So having to burn in a product that you are effectively paying for burn in doesn't make any sense to me.
Except what’s usually reported is a roller coaster ride, especially early on. Hints of the magic appear along the way and then finally things settle and all one is left with is just that magic.Having never heard a difference with any fuse, audiophile or otherwise, I must be stone deaf. I do wonder if psychologically it's possible to wait 200-300 hours and then not hear a difference!
When one needs to maintain a delusion, profound cognitive dissonance can be felt when reality intrudes on that delusion. The only way to deal with that when one is unwilling to discard their delusion is to try to rationalize it away. In extreme cases, some actively try to redefine reality so it conforms to their delusion. Not saying that’s what’s going on here, but when there is evidence of repeated attempts to misrepresent or mock what others have said they observe, there may be some form of that at play.Impatience about burnin aside, psychology comes into play when instead of looking in the mirror to their own circumstances, be it hearing, equipment or finances, some people instead disdain the abilities or honesty of others who do hear differences and then make it known by disrupting forum discussions.
Excellent advice.If so, I suggest that you listen every day and take notes about aspects of the sound that stand out to you for better and worse. If you can hear differences, then over the course of 300 hours or more your notes will tell a story, and it won't be one of continual improvement. If not, then either your equipment or your hearing is not sensitive enough. In either case, find what you enjoy. That's the point, after all.
My integrated amplifier does not have an external fuse. Nor did my previous integrated amplifier. My previous streamer (Innuos Zen Mk3) used a 2A fuse, it came with Littelfuse installed, after several years I replaced it with a SR Black. I cannot say that I heard any difference, when new or later on.Entirely possible. Everyone's hearing (aural-brain connection) is different and many people suffer from limitations significant enough that even with experience they are not able to hear many essential kinds of differences that others can (it's possible for serious dedicated training to partially overcome that in some cases). Impatience about burnin aside, psychology comes into play when instead of looking in the mirror to their own circumstances, be it hearing, equipment or finances, some people instead disdain the abilities or honesty of others who do hear differences and then make it known by disrupting forum discussions. I'm not clear from your post if you are currently burning in a dedicated aftermarket audiophile type fuse or two right now or not, that is, something far more able than the Littlejohn is likely to provide. If so, I suggest that you listen every day and take notes about aspects of the sound that stand out to you for better and worse. If you can hear differences, then over the course of 300 hours or more your notes will tell a story, and it won't be one of continual improvement. If not, then either your equipment or your hearing is not sensitive enough. In either case, find what you enjoy. That's the point, after all.
Can you tell me what the QSA process is. I asked the UK distributor. He refused to tell me.The QSA process doesn‘t aim to burn anything in the way running current through it would.
Not that you’ll get anywhere, but there are two threads for that discussion:Can you tell me what the QSA process is. I asked the UK distributor. He refused to tell me.
So I looked online and found a video of Mr Tsang doing the process to a cable. He is running a current through it, because it is is attached with a cable clip. The video is still there, it's easy to find.
The QSA process is non-invasive. If it's not running a current through the fuse/cable, what on earth is it?
It’s a proprietary process.Can you tell me what the QSA process is. I asked the UK distributor. He refused to tell me.
It sounds like you convinced yourself that they couldn’t possibly make a difference. I think if you polled those who hear improvements from fuses, 99% of the would say they have no clue why they make a difference, but they sure can bring improvements.What gets me about fuses is the idea that they are a bottleneck, the weakest point in any system. It's just not true. The current through my 3.15A SR Black (or the 2A fuse it replaced) will never reach 0.1A. It will not heat up under load. The resistance will not change under load. If people hear improvements with different fuses, then that's good for them. Personally, I don't.
If I'd convinced myself beforehand I wouldn't have bought an audiophile fuse.It sounds like you convinced yourself that they couldn’t possibly make a difference. I think if you polled those who hear improvements from fuses, 99% of the would say they have no clue why they make a difference, but they sure can bring improvements.
Many years ago I read an explanation someone knowledgeable put forth about why fuses could have such an outsized influence. I wish I could remember it but, as one might expect, the size of the element was a key consideration.
I think it would be foolhardy to reach any conclusions about the audibility of fuses without trying to understand what is different about passing current across such a small conductor. Physics would suggest there has to be a difference, particular when dealing with dynamic current. I don’t know if you are right that in your example l that it “will never reach 0.1A”, but that may be too simplistic of a way to think about it with components that are tasked with meeting instantaneous demands for current.
It's not simplistic at all. I spoke to Dr Sean Jacobs, who designed the power supply that the fuse was attached to. He explained that the Innuos Pulsar has a version of his popular ARC6 design. The peak power consumption is 13.7w, less than 0.1A with our 230v supply, in fact closer to 0.05A.
The Innuos units are fitted with Littlefuse (cost $1). Innuos for their part give instructions on fuses, where to get replacements, and advice if you use an audiophile fuse, including increased value and directionality.
I'm not sure you can get more even-handed than that.![]()
Replacing the fuse on Innuos products - Innuos - High-Fidelity Digital Music Servers and Streamers
How to replace the fuse on any Innuos modelinnuos.com
Fuses are sophisticated devices with a vast range of designs for different applications. The sophistication seems to be in providing unchanging performance up to rated load and then a wide range of performance characteristics in over-current load. When you talk about dynamic current, I think you are talking about over-current conditions. There are fuses with specifications to deal with that. You will see them used in high current amplifiers.
I don't agree that they are a small conductor. They may seem small to audiophiles conditioned to mega-thick cables. The size of the conductor is determined by the required specification. The conductors in audiophile fuses won't be any thicker.
No, that’s not what I’m talking about. I thought my mentioning “components that are tasked with meeting instantaneous demands for current” would have provided sufficient context.When you talk about dynamic current, I think you are talking about over-current conditions. There are fuses with specifications to deal with that. You will see them used in high current amplifiers.
Yet again you misrepresent my argument. I’ll stop now. I agree with the post above. Time for you to move on.I don't agree that they are a small conductor. They may seem small to audiophiles conditioned to mega-thick cables. The size of the conductor is determined by the required specification. The conductors in audiophile fuses won't be any thicker.
