Audiophiles and our prejudices
FrantzM
30
405
Hi
This was prompted by an audition I have had at a friend of a speaker I am sure most audiophiles have heard of but likely have not cared to listen to. I know I wouldn’t have if I weren’t pushed in to it but .. I am getting some what ahead of myself…
I have come to consider our deeply stated prejudices. Not of the really shameful ones, rather of more subtle mindsets, which will have use rejecting outright things we haven’t heard… It goes both ways both on the subjectivists or the objectivists side .. No one is spared.
For example we go around saying that the brand is of no importance to us.. Yet.. If we come cross a Lamm compared to a brand say a Denon we will likely think the Lamm superior it wouldn’t matter that this particular Denon could be an all out assault on the High End by a brand which knows a few things about High End Audio.. Same would have happened if it were a SONY .. You get my drift …
Well , my experience was a speaker that I am sure most here would dismiss in a hurry, I included, yet this a real effort at the SOTA and in the realm of High End Audio not an expensive speaker …
The speaker is active, something most audiophiles would reject too but , some of us are warming ourselves to the fact. Several of us are actually using active speakers in our set-ups without thinking about it a lot .. Those with powered subwoofers please raise your hands! :) Some SOTA speakers are active in the bottom and this with superior results if you ask me .. Genesis 1, 2 anf 2 Jr, Von Schwheikert VR-9 & 11, Evolution Acoustics MM2,3 and 7 … there are more …
The speaker in question from a brand not reputed for good sound … Interestingly enough, Audiophiles had to give up to the excellence of the JL Audio subwoofers. JL Audio made their name in Car Audio … I will have to come back on this as many of these car-audio-buffs could show many of us a thing or two about bass reproduction … Oh yes! people some of these cars have bass that will shock many home audiophiles in the quality of their response .. not all of course. Some, the same way some so-called audiophiles systems are frankly bad and do a disservice to music reproduction … back to the speaker in question
It is active, has several kilowatts of amplifications, is good looking and the finish is well above most high end audio products. The people who designed it don’t believe in cables at all. Some of the connectors are not gold-plated and in many cases the cable they use is nothing that any audiophile I included would put in their system.
The owner paired his speaker with a tube preamplifier Antique Sound Lab preamp, The top of the line Supra to connect his preamp to the speakers and some room treatment. Result? A very good system. One that would shock more than one, and indeed shocked me.
The speaker? The Bang and Olufsen Beolab 5. It will wipe the floor with many audiophile speakers. It has its own amplifier and DAC. It simply require a source as it can control its own volume by its lone self. It is digital. It converts anything fed to it to 24/96 .. I don’t know if the feed to the amp is digital but it converts the input to digital from what I have read .. and it sounds good . Very good. Much better than we audiophile would even care to admit.
I have heard the speakers at B&O stores and for the most part I always found it dry, …and with highs to cut steel… Well in a controlled environment, one with some acoustic treatment, what I heard was a serious attempt at a High End speaker. The bass in particular is stupendous. The midrange honest, highs ok to good. Soundstaging in particular is first-class. The sheer SPL capability is astonishing this thing plays loud and with no sense of strain everywhere. Your ears will quit before it does and it is no one-trick pony it can play soft, great sense of dynamics. Bass will shame many a subwoofer and not necessarily cheap ones. It goes low, very, very low and with a sense of ease that few high end speakers , aside from those with powered subs possess. I can’t say much about the room correction it seems to work well.
All and all, a good speaker, one that I would not mind for a secondary system or better for a Home Theater. It is not the equal of the better High End speaker systems but it would rout quite a few and some of them more expensive… And think of it this way, it is a complete system all it requires are sources .. Feed it SPDI/F from a good server (I am still using Gary’s) and one has High End performance .. Think about it this way. The pair is $25K You add a decent music server at say 1K..End of the story… I can see how with a Kaleidescape or similar ergonomic music server would be at the service (pun intended) of music enjoyment wit h this speaker.. Minimal tweaking maximum joy to paraphrase Sade Adu …
This lead me to think how prejudiced, we, audiophiles truly are. We don’t like certain brands and this cloud our perceptions. We respect some brands nd look down upon others .. A Denon can’t be that good , even less a Sony or a Yamaha … On the contrary for the aficionados some brands can’t do no wrong .. Even if they ask us to wait 500 hours before we get used to its sound ... sorry... until it sounds really good! We will gladly accept their quirks and unreliability in the name of the name and of the sound we think we hear .. More on this later .. The thread is not really about the Beolab 5, it is about our prejudices …
Nice post, Frantz. Some people, shock, horror, even think Philips is a bit of a nothing brand, tsk,tsk. But I know what you mean about the Beolab: I listened in their showroom and it was a bit of a disaster, not least because their very fancy CD player was working as well as a 10 year old unit from a discount store.
An all-in active, digital speaker should be an absolute killer if you get everything right, the last thing is still the problem: Meridians so far haven't done it for me, the trouble is the manufacturers find it so hard to get their head around the issue that everything's important, they get 95% spot on, and then go sloppy in key areas ...
Frank
Frantz,
Just one point - the european audiophile community has discovered the The Bang and Olufsen Beolab 5 some years ago. It received several rave subjective and objective reviews - even Martin Colloms, the man behind the PRAT, gave it an excellent appreciation and it received the honors of going in the "The Collection" yearly supplement of the best of HifiChoice.
IMHO, the marketing problem behind the Beolab 5 marketing for audiophiles is the usually inferior quality of the Band and Olufsen source components, that have an excellent design but are connoted with average audio performance and can not complement an usd 25000 speaker.
BTW, it is interesting that your friend uses a tube preamplfier with the 5s - an old receipt for driving active speakers, such as the Meridians and ATCs was using a balanced ARC tube preamplifier. Did you listen to it in pure digital mode?
Just a last comment - in Japan Denon sold ultra expensive audiophile components designed with the same "fancy" trends, such as single output transistors, that we find in recent modern units, in the 90's!
Unfortunately no. I would have liked it but the person is a set and forget kind of guy. THe system seems to be set-up so that everything goes through the Tube preamp. Source are only digital. Cd player is a Metronome that seems to go through the Tube preamp and volume is controlled through the preamp NOT the speaker in this case...
The experience had me thinking about many of our assumptions, biases and yes , prejudices ...
this reminds me of the first time i heard a set of the active Meridian M2 driven by a levinson Ml-7 preamp and Linn sondek front end - must have been around 1986-7. I was gobsmacked! the transparency, dynamics, tonal quailties and staging abilities easliy matched the ESL-63 in the other demo room -and bettered them in many other ways. it got me thinking then and I realized there is much to be said about active speakers in general.
The M2 was all-analog and primitive compared to DSP and other advancements today. Back then you couldnt find the M2 reveiwed anywhere except a mention in HiFi News & Record review. In many ways the bias is still prevalent in the high end media today--i believe--driven by the un-informed vs. those that understand the potential of active designs and in most ways the technical superiority. That said, I never owned a set in my life :eek: Im currently shopping for a pair of the active Dynaudio BM12a or 6a to run straight out if my DAC/preamp, just to mess with - finding a dealer to audtion them is the challenge even in LA.
_ :)
__________________________________________________
Great examples.
The upper one reminds me of cala lilies. I recognize the lower one as a B&W Nautilus. Very appropriate name since it has a separate chamber for each driver. The Nautilus looks as if it is in rapid motion.
In search for other interesting shapes, I checked out the Dali line. They don't live up to the name.
Bill
No accounting for taste, but I think the lilies are dumb, the Beos are a bit goofy and the B&Ws are gorgeous.
And of course I think Aczel is right :).
Tim
Hi
Somehow back to topics. The Beolab 5 looks much better in person, the pictures don't do justice to its looks. It exudes quality build and spartan aesthetics .. The point to me is how much debate we go into without questioning our biases. Especialy negative biases: I came to the speakers unimpressed from prior listening and with a secret sneer. There had to be some smirk on my face too. I had planned to go to the audition with a portable HDD but since it was to be a Beo speaker thus an inferior one I went with a 2-CD compilations of cut I liked and that would just bring the wannabe to its knees...
I remember thus that back in the days I did not like the sound of early high end SS. I never liked Mark Levinson for example and IMO Bryston had to be in PA system not a high end one. This changed when I heard a year r two ago, the Bryston Top of the line monoblocks with Revel Salons ... As for Mark Levinson, I am remembering now that the prejudice is still alive.. I haven't heard any of their designs for decades :eek:
Prejudices carry to what medium we listen to. I have heard tales of Audiophiles fooled by this. They would see a TT and yet were listening to a CD and the whole lexicon of analog qualities would come upon listening to what they thought was a TT reproduction! I have personally seen audiophile fooled by non-swap in cables to say they did prefer Cable A to B or C when there were no change in cabling! I was one of them, this happened in my own house on my own system ... I came chastised, humbled and a intense non-believer in cables.
Some of the preferences that we show stems from such prejudices. I have no doubt that one can hone his or her auditory acuity. Our hearing apparatus is dominated by psychology and for some it is a truth too hard to swallow.
Hi
Yes.
I've had your cable experience in my home as well. And I've had a similar experience with amplifiers, dacs, WAV vs Lossless vs compressed, DACs, and headphone amps. Did it convince me that there is absolutely no difference between any of the examples of any of the aforementioned products? No. Of course not. I don't really even believe, as I joked above, that Peter Aczel is completely right. But it sure made me question the conventional audiophile wisdom and take all reports of "night and day" differences, unsupported by any objective evidence, with a large serving of salt.
And of course most of the audiophile community's mileage varies. By a huge margin. A night and day difference.
Tim
I will not be baited. I will not be baite.! I will not be baited. I will not be baited...
:D
Come on Greg! Between friends :)
Agreed. (and Amen!!)
I know John Dunlavy did this all of the time to the cable manufacturers that came to visit him. And a local high end dealer used to do so as well and no one ever caught either one of them.
I. too, have been baited by those same prejudices
When you are subject to a "blind" comparison and do not know you are being tested, then the argument of "blind test stress" goes out the widow!!
All of that said, I'm pretty sure that fat cables sound a lot better than thin ones :eek::eek::eek:
(see my Tolstoy quote below)
