Thankfully we don't in general but let's keep going....
Not true and I am speaking for you, not myself. When you listen to a loudspeaker you have no idea of what something is supposed to sound like. None of us do. What we magically seem to do, is search for flaws. It is absence of flaws that then yields the adjective of "excellence."
This is easily demonstrated. Take your clock radio and turn up the volume to 100%. The sound gets distorted. And all of us can hear that distortion and as such, rate that experience as negative. We are all good at hearing such flaws and removal of them all is what gains our praise.
The loudspeaker blind tests I participated in has been taken by hundreds of others with majority coming out of with similar results. So we are not different, no matter how hard you try to factionalize us.
When you listen to a new loudspeaker you immediately focus on what it is doing. Are the voices natural? Is the bass good or boomy? Are the highs clean or tizzy?
Your doctor does the same thing when you see him. He looks for what is wrong with you because that is what he is supposed to do. Likewise, if you are comparing a set of loudspeakers, you naturally and intuitively search for what is wrong with a loudspeaker you prefer less. That is the job at hand, not talking about going fishing with your doctor.
Now, that said, just like your doctor, I am different than you in that it has been part of my training and audio journey to find artifacts by ear, and be able to correlate it with technical deficiencies. So while my preferences are no different than majority of people here, my analytical abilities have been improved so I can arrive at the "answer" faster and more reliably.
Does the above stop me from also detecting excellence as you imply? Of course not. What a silly statement to make. You play a great sounding system with great content and I start dancing to its tunes as fast as the next guy. Make that an AB test though and all of us will search for flaws that detract from one system but not the other.
It was a struggle getting all of them into my room at once, and obviously I had to call in four or five friends to swap the speakers around, fortunately Harman lent me their hydraulic 'shuffle' system from one of their evaluation rooms.
Keith.
So, you're asking us to believe you managed to acquire pairs of Ces Liszts, AG Trios, Tune Audio Animas, the big Blumenhofers? You then got piano movers to get them in your house? You then did unsighted trials where you had no idea which spkrs were playing, switched them out, and demoed again. 4 horns means 24 permutations, maybe you had 5 pairs? Or 6? Tell me when to stop.
How long did this all take? Especially since horns more than most need careful setup. You didn't set them up 'cause this was all unsighted, so someone else did.
Gosh, you must take us for fools if your mantra of unsighted demos extended to SOTA horns.
Maybe your rinky dinky K111's, but serious audiophile spkrs?
It doesn't matter how many people think X vs Y. By that notion you lose to objectivists because there a ton of them believing the opposite of you. You are putting a hypothesis forward and it is your job to demonstrate it being true with data. Not saying, incorrectly as I explain below, that more people think like you.I have since sometime understood that the idea that we do not have intrinsic references and just look for flaws is just the source of most of our divergences. Many people use specific references for sound quality - the sounds of natural instruments. We have many people who support this view in WBF and elsewhere.
Guy goes to buy steak and asks the butcher how much it is. He says $20/pound. He complains by saying that the butcher across the street has them for $10 pound. The butcher asks him why he doesn't go and buy the steak from the other guy and he answers, "he doesn't have any!"As far as I saw in the published data, the results did not show similar results - they showed a majority with similar results, something quite different. And somewhat expectable, considering that Harman created the conditions and methodology of the tests, that aim to identify and produce the speaker preferred by majority - a meritorious task I must say. Surely audiophiles are not a group large enough for Harman science - they never tried to reproduce their typical conditions or cared about their specific desires in their publicized tests , although they produce excellent very expensive speakers targeted for them!
Give us an example please.I do not focus on bass or treble or medium when listening. I focus on specific musical aspects of recordings I use as references.
That aside, your explanation above is completely consistent with what I said. If you think a violin sounds wrong on one loudspeaker versus another, then you put blame on one. Your claim was that you don't think that way and that you only think of excellence. Prove that no one evaluating loudspeakers as you say, doesn't think one representation is worse than the other and then we can talk.
By the same token, you don't have any experimental data that "we all listen differently" but are full complaints about others who have done the testing and published them. If you are sure of your point of view, you should test your hypothesis the same way and present the data. Don't appeal to talking down other work with nothing of your own to present other than, "there are others who think like me."
This a not a thread on blind testing. It is about trusting ones ears. Indeed if hearing, or the ears is the only sensory perception in play one could argue the subject is even more dependent on his ears in a blind test. It is human nature to favor a test that yields results we already believe to be true and vice versa.
Nor is this a thread about Martin Logan I was and still am a long term fan of some of the Martin Logan lline. I also owned the ML CLSI and briefly owned the ML Aerius. I tried to read all the reviews and measurements available. I also listened to my audio buddies ML CLS. No measurement ever changed what I beleive I was hearing. Yes there was a time I believed it was the best, No doubt there are "better speakers out there including the ML Statement e2.
Having someone say the ML( I do not remember which was under evaluation)is flawed as a matter of opinion does not bother me. Representing it as a fact is another matter. Even more intriguing would be the claim that you made that decision after observing measurements and ignoring what you heard in favor ofI these measurements. I have previously stated I find that fascinating behavior.
Basically what you are saying is; you heard the Martin Logan; liked it,;then you heard it blind compared to others and liked it less. Possibly our opinion was supported by measurements. Good ffor you. What speaker is not flawed? Transducers are generally considered the most flawed in the audio playback chain. To me when the CLS was in the right room and associated with the correct equipment, it brought to reality the incredible potential of the electrostatic genre and adequately addressed many of its shortcomings. To me saying it is flawed, or that you changed your opinion, or that you heard speakers that sounded better is just part of the audio journey.
Greg, just to clarify, the whole of my sentence is:
"Amir, Reading that the Martin Logans are flawed and seeing graphs of the Harman test results in these forums showing the poor preference results has introduced expectation bias against these speakers."
By quoting only the highlighted phrase as you do in your post, it implies that I think this about Martin Logan speakers. Actually, I don't have a formed opinion about these speakers. I am attributing that sentiment to Amir. My point is that I am getting that impression about the Martin Logan speakers by reading what Amir has posted and that he has introduced an expectation bias to me by his comments. I wonder if it will now influence what I think about them when I next hear them in my friend's system.
He was joking, and to be fair he has made that statement in jest not expecting people will believe him
YeahGreg, just to clarify, the whole of my sentence is:
Peter,
Do you know the exact conditions in which these ML tests were carried? Just imagine you loved Mini II being evaluated in these conditions. My Magico distributor still has a pair of Mini II's and unless properly set , amplified and tweaked they sound thin and disagreeable. But once they positioned them properly and fed them with an Audio Research Reference 750 with Transparent Audio top cables we were in musical heaven!
Ears can't measure. Let's see 8 x 5% would be 40% distortion. Assuming the distortion is cumulativeSo you trust your ears.
well now, say we are talking about your audio memory of what a violin sounds like.
What do you rate the ability of your system to sound like your obviously trusted audio memory reference of how a violin sounds, in percentage. OK, so you say your system is 95% there.
how much of that 95% is the room
how much of that 95% is the speakers
how much of that 95% is the power amp
how much of that 95% is the pre amp
how much of that 95% is the source
how much of that 95% is the interconnects
how much of that 95% is the power cables
how much of that 95% is the speaker cables
how do you parse it all up, each component you put in your system you hear a difference, and it is always an improvement of every sound if you keep it, OMG.......
I had a post on this exact subject some time ago with specific examples of recordings - I will try to find it. As far as I remember it is filled with what you consider "poetry", I doubt you will find it of any use.
You didn't present any ideas. You declared how I evaluate products and how you evaluate products. I explained how that is wrong and data shows that to be the case. Your answer is what now? That you are not trying to convince other people? What does that have to do with price of tea in China?You fail to understand I do not want to persuade practicing objectivists - they have their strong beliefs and they are in such a small number in this forum that I do not want to reduce it- I only present ideas I appreciate and I suppose our members will enjoy reading. They are not mine - we can read them in article and interviews in TAS, Stereophile and many internet sites.
No, you need to remember that we are discussing this because you said this about *me*:Should I remember you anyone can have an opinion on anything without needing to have or defend an alternative?
I would think that if you are saying something about me, you would be willing to defend it.We all have different ways of listening. It is curious that you seem to be mainly listening for flaws. When I listen to speakers in an appropriate system I listen mainly to the excellent and exceptional aspects of their performance and if they suit me I am prepared to forgive some aspects where the competition sounds better.
Again, none of this had to do with the topic that started this. I am asking you to demonstrate how you are different than all the rest of us in not looking for flaws in loudspeakers, especially in AB comparisons.High-end exists. It creates excellent sounding SOTA stereo systems. As far as I know we have a forum that wants to debate everything connected with such systems. If the existing science can not explain it fully and clearly and has no interest in researching it, we do our best to find our own way. And enjoy ourselves, BTW.
You have to find a post??? You can't give us an example of this: "When I listen to speakers in an appropriate system I listen mainly to the excellent and exceptional aspects of their performance and if they suit me I am prepared to forgive some aspects where the competition sounds better."I had a post on this exact subject some time ago with specific examples of recordings - I will try to find it. As far as I remember it is filled with what you consider "poetry", I doubt you will find it of any use.
someone had to take a stab at it. I suspect few others will.
