Aurender N30 - To stay competitive in 2021
Changing ethernet cables or otherwise optimizing the ethernet does not make a difference with the N30SA here (in contrast to my old Aurender S10). The isolation of the N30SA LAN port apparently works very well.
The N30SA wants the best power cord you can get, wants to stand as vibration free as possible. It talks to my DAC over the SPDIF protocol via an 110Ohm XLR cable, aka AES/EBU. I found this sounded better than SPDIF over RCA. I use an in-akustik air-silver cable.
I put the N30SA onto IsoAcoustic Orea feet. It hates vibrations.
The N30SA is a beautiful naturally sounding device. I mainly play local files but even streaming sounds good. I have not heard any better music reproduction outside of ultra high end analog.
beautiful system! Regarding the Oreas, did you end up using the Indigos?
Reactions: Solartiger
Suspect this is a question best answered by Aurender dealers…is Aurender developing direct ISL interfaces that brands like Pink Faun and Taiko are developing/releasing for top DACs manufacturers such as MSB, etc? And, if so, will they be compatible with the N30SA, N20, etc?
Hi, I would need some advice. I have an Aurender N30. I would need a longer umbilical connection cable (power and signal) between the 2 units. Can anyone please advise where I might be able to get them?
Are you in the UK?
No, I live in Malaysia. But I can order from the UK. May I know what is the reason you ask whether I am from the UK? Any local supplier you have in mind? Thanks! :)
I recommend Tony Sallis at Coherent Systems https://coherent-systems.co.uk/
In addition to being a UK retailer of Aurender machines, he is also the authorised UK service agent for Aurender and has an N30 in his demonstration system.
I know he has made some extension umbilicals for clients and his own N30.
His Coherent 6D Gen II cable is rather special. I have them in my own system at home.
A better umbilical sounds better I heard, can anyone comment on that?
I’ve had few conversations with Aurender Chief designer, he recommended to stick with stock umbilical cords. I brought up this topic as I was fiddling with off-market data umbilical cable and the two I have tried didn’t made any audible differences, YMMV.
Reactions: Pokey77
