There is a lot of talk about using a linear PSU to power your dedicated audio PC.
Will sound quality really improve?
I tried a simple test using my laptop.
Measure it using the AC adapter in place and do the same when running on battery only.
Running on AC
Running on battery
Obvious running on battery creates a lot of distortions
This is the power saving schema.
Better put it off.
Running on AC
Running on battery
Better put it off.
