The restarts didn't fix the issue. XDMS does have the new IP address. I'll contact support now.Also, just to cover the basics - you changed the IP address in XDMS after installing the router, right?
The router will change the IP of your Extreme and you need to update XDMS with the new IP Address. I assumed you had done that because you said you could play local files.
Ed jumped in right away and provided the solution. I needed to uninstall/reinstall XDMS on my iPad and re-enter my credentials.The restarts didn't fix the issue. XDMS does have the new IP address. I'll contact support now.
Thank you, nenon.Also, just to cover the basics - you changed the IP address in XDMS after installing the router, right?
I did. Everything works again. Thx!I would power cycle the router.
