As the Taiko Router Wi-Fi is static, it’s more likely another acces point causing issues.
In case you are experiencing some connectivity issues and/or want to make sure you don’t run into any issues in the future, you could change the Taiko Wi-Fi to operate in 802.11n mode. It will then work on both 2.4G and 5G. The few who have done this actually hear no difference at all. I can hear a small difference but it’s small, like less then 1%.
Perhaps this is a situation where one should not go for the absolute last attainable drop in exchange for a bit more comfort.
We’re considering to making this standard, we could include it in a firmware update. Should you want to have the absolute minimum interference possible you could change it back to 802.11 legacy mode manually then. We could also look into making this an option in the upcoming remote support app.
