Thank you, Chris! I have always thought the LP-S was fantastic!I spent the afternoon going back and forth between the LP-S and the London Decca Reference, playing tracks on both. I always thought the Reference was my 'forever' cartridge, and others were just stand ins for it. But I have to say, the LP-S outperforms it, making it sound a little bit muffled in comparison. Well, as shocked as I am by that, it does make my life a bit simpler. I have now mounted the LP-S on the Series V, and the Cadenza Mono on the Series IV and that's going to be it, unless I change my mind again!
I'll have to ask Lee Drage at Acoustand if I can cancel my order.
Ron, the Statement 3 is confusing to me. Others say it is wonderful, and deserves its place in the Lineage series. I have run it both as MM (output is 1mV) and as an MC with various loadings (where I liked 100? best). But it doesn't excite me. None of the speed that a Decca has, and which a relatively humble MP-500 simulates very well. Not as lively as the Sussurro even. I haven't mentioned it, but I also have a London Jubilee, which impressed me enough that I quickly stepped up to the Reference. Even the Jubilee makes the other MI cartridges seem a bit dull. The Decca design really has something special, and after John Wright bought the rights from Decca he made them lose their well-known faults of unreliability and humming. I really never expected the LP-S to put them to shame, but there we are.
Chris
Hence any cart manufacturer will freely tell what they use for cantilever, coil, body etc., but never what is the suspension hahaThat’s why loading suspension is very important. It shouldn’t be too loose to act like a MI and shouldn’t be too stiff to diminish dynamics.
The dynamic sound associated with moving iron cartridges is mostly due to lack of suspension. When the stylus moves from one side to other in the groove there isn’t enough damping stop it. Because stylus and cantilever have a mass and they can not move or stop instantly. Even though it’s a small mass but still big enough regarding the groove size. As a result it reads artificially exaggerated dynamics.
MI does not only benefit from producing dynamics with the lack of proper suspension but also the lack of a horizontal cantilever. Instead they employ a silk string to keep vertical cantilever in place. I’m not saying using or liking a MI cartridge is wrong. I’m only saying cartridges are reading dynamic swings stronger than they were actually etched in the grooves. MI does this more exaggerated than MC. That’s all.Can you show me that MI cartridges "lack suspension"? And how shall that statement apply to the Decca design, where all normal bets are definitely off? I'm happy to engage with your statements, but let us be clear about the engineering involved.
My intention wasn’t to start a fightNow, @mtemur, this is fighting talk!:
Right then. You seem to address the Decca design with the "lack of a horizontal cantilever" remark (anyone unfamiliar with the design should look it up). And, while still avoiding starting any fights, I have to address this. Decca made stereo cartridges. Their cartridge design is certainly as orthogonal as one can get with horizontal and vertical coils and magnets, yet they wired them to respond to the 45º channels of a stereo disk. Not hard to do. Now can you show me that the "lack of a horizontal cantilever" impaired their ability to play stereo properly, especially when you say the silk tie-back string was to "keep the vertical cantilever in place"? No one has ever suggested that Decca-design cartridges were incapable of playing stereo (and I assume you are giving Grado, Soundsmith and Nagaoka a free pass here as they don't use the cantilever-less design of a Decca, even though they seem to be included in your comments about MI cartridges). May I assume this critique is also applicable to Ikeda cartridges?MI does not only benefit from producing dynamics with the lack of proper suspension but also the lack of a horizontal cantilever. Instead they employ a silk string to keep vertical cantilever in place. I’m not saying using or liking a MI cartridge is wrong. I’m only saying cartridges are reading dynamic swings stronger than they were actually etched in the grooves. MI does this more exaggerated than MC. That’s all.
Who said it cause certainly I didn't.Their cartridge design is certainly as orthogonal as one can get with horizontal and vertical coils and magnets, yet they wired them to respond to the 45º channels of a stereo disk. Not hard to do. Now can you show me that the "lack of a horizontal cantilever" impaired their ability to play stereo properly
What did you not say that I responded to? Otherwise I consider all my questions answered.Who said it cause certainly I didn't.
I didn't say or imply that DECCAs can not respond to lateral and vertical modulations by saying "lack a horizontal cantilever" or "silk string to keep vertical cantilever in place". I was simply describing DECCA's design differences apart from Ortofon MC (almost all MC cartridges) in a mechanical standpoint.if you are correct that Deccas "lack a horizontal cantilever" and have a "silk string to keep vertical cantilever in place" it sounds like they cannot respond to either horizontal or vertical groove deviations properly. How then, do they play music at all? We all have heard that they do so, and a few lucky ones know it from experience.
SoundSmith doesn't share the same design with DECCA. They're more like moving magnet. Stylus at one end of the cantilever and the cantilever is suspended from the other end like a conventional cartridge. IMHO DECCAs have a unique MI design and others are similar to conventional design. But as I said before all cartridges are effected from this phenomenon, some more, some less depending on the damping of suspension. BTW it's my mistake I should say DECCA MI instead of MI at the first post. Sorry.@mtemur, I’m finding this information about MI quite interesting, so thanks! Would you say (or think) that the MI design used in SoundSmith cartridges show a similar degree of “enhanced dynamics” to that of the Decca?
Those are exact quotations of the words in your post.I didn't say or imply that DECCAs can not respond to lateral and vertical modulations by saying "lack a horizontal cantilever" or "silk string to keep vertical cantilever in place". I was simply describing DECCA's design differences apart from Ortofon MC (almost all MC cartridges) in a mechanical standpoint.
Ok, they're exact quotations from my post.Those are exact quotations of the words in your post.
What? May I not quote you in reply?Why you implemented those quotations differently?
Good decision, cause you were dragging this to the things I didn’t say.In order to avoid the notice of the moderators here, I shall stop here.
