I do prefer to listen to classical music the most. I know that Sonus Faber has naming and visuals that allude to violins, so it's satisfying to hear that they functionally excel with strings and classical music.I would suggest:
(1) Ask yourself what genre of music you prefer or will listen to the most. My experience is that high-end speakers tend to favor in terms of "believable reproducibility" one genre over another. For example, Sonus Faber speakers excel on orchestral, classical, jazz, especially strings. They are not particularly "good" on hard rock or metal genres. In contrast, I find Focal, Magico do not reproduce classical music well, but are tuned more toward rock and similar genres. Wilson has a unique sound that is very clinical to my ears.
(2) Do you like very detailed sound even at the expense of "warmth?" Wilson's provide every last detail, clearly differentiated. Detail is present, but perhaps in a warmer or more natural way with Sonus Faber and hence the latter may not sound as "articulate".
(3) Be aware that the "upstream" components greatly influence the sound of the speakers. Do you want "tight" impactful bass? Perhaps you would prefer a solid state amp. A "warmer" tone, then perhaps a tube based amp. The preamp also influences the sound and you can certainly mix and match (I have a tube preamp and a solid state amp so I get the "best of both worlds".
(4) Cables make a large difference in the sound as well. I find, for example, the NOrdost line of cables to sound as if there is a veil compared to the Shunyata cables.
In other words, there sound that emanates from the speaker is not dependent only on the speaker per se. You have to go and listen to entire systems.
(5) The precise speaker placement, the room and its treatment are critical. This will take days of experimentation, but in the end can truly provide a wide and deep soundstage and speakers that seem not to exist.
Good Luck on your endeavor!
I honestly don't really know what type of sound I truly like, but I did read that very clinical sounds can be tiring for prolonged listening. Do you agree?
It's fascinating to know that the cables also make a difference. I have seen systems where the cables are placed on small stands. Do they also make a difference?
So I understand now that only the sum of the parts can be assessed as being the best for anyone.
Thank you for the kind words and insight!
