Please just cite one recognized authority accepting a single blind study as a recognized standard.
I think that you're confusing the degree of scientific rigor that's appropriate for a peer-reviewed scientific journal versus what's reasonable to offer up as evidence in a WBF thread.Single blind test are allowed but only when that is the only option. It is irrelevant here because it is so easy to achieve double blind. When you use single blind they are less reliable.. Impossibility is the rationale for a single blind test. Not inconvenience or informality.
Thank you.I think that you're confusing the degree of scientific rigor that's appropriate for a peer-reviewed scientific journal versus what's reasonable to offer up as evidence in a WBF thread.
So seriously take the results and methodology of the test being discussed and tell me what you could reasonably conclude based on the results. Don't worry there is no wrong answer.I think that you're confusing the degree of scientific rigor that's appropriate for a peer-reviewed scientific journal versus what's reasonable to offer up as evidence in a WBF thread.
You spilled considerable digital ink railing against single blind test results. My post was just pointing out that the rigors of double blind testing & other controls shouldn't be a requirement if an objectivist audiophile simply wants to enlighten folks on a forum about some single blind test results. They're without a doubt far better than sighted tests if one wishes to divine whether A is better than B.So seriously take the results and methodology of the test being discussed and tell me what you could reasonably conclude based on the results. Don't worry there is no wrong answer.
Ok. you would generalize from the specific. Fair enough.You spilled considerable digital ink railing against single blind test results. My post was just pointing out that the rigors of double blind testing & other controls shouldn't be a requirement if an objectivist audiophile simply wants to enlighten folks on a forum about some single blind test results. They're without a doubt far better than sighted tests if one wishes to divine whether A is better than B.
Youl are a brave soul to argue science on WBF. I admire your moky. There are very few folks on this forum (myself included) who would agree with your cited studies because most folks here choose, for better or worse, a subjective approach versus objective criteria. It is simply a difference of opinion.k, you've tried to play every card to avoid you've been wrong and haven't addressed my real arguments.
In the end, this type of discussion is a black hole. No one is right or wrong.
Good list, but if the test participants are blinded, then the "preexisting bias" factor is eliminated and you don't have to screen for it in your participants. That's why it's important to do blind testing.Basic factors not discussed
preexisting bias against the efficacy of the subject under test. If you already believe the product is snake oil or incompetent you are not a good test subject.
Which of these would you be willing to sacrifice and still have confidence in the results?
Your points don’t invalidate double-blind testing - they just emphasize that it’s difficult to do it well. This trope is often trotted out to discredit double-blind testing in defence of the typical, subjective tests that most audiophiles, including reviewers with (apparently) superhero caliber aural memories conduct.Basic factors not discussed
Truly double blind- a test examiner who does not anything about cables. their ignorance would tecnnicaly make them "blind" to the choices.
matched levels- people tend to pick the louder one.
music or test tones. tones tend to be preferred because you know it assures you are comparing apples to apples. Many use a 15 second clip
rapid switching- short term memory of what you heard is not very good.
multiple test subjects-very easy for one person to make a mistake or just be wrong.
number of trials-- you have to flip that coin a certain number of times before you can say anything about the outcome.
control -just to have a benchmark so to speak.
ratio of positive /to negative outcomes -informal confidence level. easy to calculate 8 of 10 would be 80%.
stake in the outcome. What was the method of comparison. Did the subject endeavor to match a to b in a binary choice? Did the listen to sevral cables and try to pick a preference? There are options.
That's just off the top of my head . Things I have learned from 10 years of debating the most vociferous proponents of double blind testing. Those issues should be addressed even for "evidence on WBF". IMO YMV.
I is not a trope. It is a summary of double blind testing protocol. I have no desire to invalidate double blind testting. But if they are to have any credibility the must be done properly. "It is difficult tp do well." Science is hard sometimes.Your points don’t invalidate double-blind testing - they just emphasize that it’s difficult to do it well. This trope is often trotted out to discredit double-blind testing in defence of the typical, subjective tests that most audiophiles, including reviewers with (apparently) superhero caliber aural memories conduct.
In my opinion, it’s in the best interests of the industry to downplay double-blind tests.
Thank you for being open minded.Good list, but if the test participants are blinded, then the "preexisting bias" factor is eliminated and you don't have to screen for it in your participants. That's why it's important to do blind testing.
As a former scientist, I agree.I is not a trope. It is a summary of double blind testing protocol. I have no desire to invalidate double blind testting. But if they are to have any credibility the must be done properly. "It is difficult tp do well." Science is hard sometimes.
I am predisposed to believe, for example, that power cord upgrades do not make an audible difference. That said, if I were a blinded test participant in a power cord test and I did hear a difference, I would certainly change my tune. I would, however, want to follow up that revelation with measurement tests of both power cords to determine why I heard a difference. Are the resistance, capacitance, or inductance values of the two power cords significantly different? If so, what would account for that? If the RCL values weren't significantly different, then why would I hear a difference? That would certainly be baffling.Thank you for being open minded.
I don't think the bias is eliminated. Would you hear a difference if you don't want to and already decided there is no difference. Bias works both ways.
Fair enough, but expectation bias is a double edged sword. I guess we could "blind" you to the fact that it was the power cord that is under consideration.I am predisposed to believe, for example, that power cord upgrades do not make an audible difference. That said, if I were a blinded test participant in a power cord test and I did hear a difference, I would certainly change my tune. I would, however, want to follow up that revelation with measurement tests of both power cords to determine why I heard a difference. Are the resistance, capacitance, or inductance values of the two power cords significantly different? If so, what would account for that? If the RCL values weren't significantly different, then why would I hear a difference? That would certainly be baffling.
That would be fine too.Fair enough, but expectation bias is a double edged sword. I guess we could "blind" you to the fact that it was the power cord that is under consideration.
