(As I have written many times I think the whole cable thing is a frustrating, but unavoidable, morass. Unfortunately for me (unlike for you with your policy decision) it is crystal clear to my ears that different cables sound different.
That's cool. Again, a high confidence in the reliability of your perception seems to be your policy, and we all get to do this stuff how we want.
But would you acknowledge that it's at least reasonable for someone else to be skeptical of what you might believe regarding cables? It seems in so many audiophile forums "Everything Makes A Difference" is the default, so you have people claiming everything under the sun "changes the sound" but a skeptical opinion is often taken as some sort of intrusion or muckraking or indicative of a closed mind etc.
I'm on the ASR forum a lot and while I absolutely agree with the general principle that, if we REALLY want to be careful in our
conclusions about audio gear, it doesn't make sense to ignore the relevance of measurements, known theory and practice, and variables like sighted biases.
On the other hand, we audiophiles aren't doing science. That would be impractical if not impossible for much of what we buy. Most of us aren't experts, and blind testing can be difficult and just a drag if you arent in to it, which most people are not. So, as I've said, I view these things as tools any individual can use...or not.
I do my best to scale my confidence to the type of differences I'm looking at. I hear a difference between speakers? I'm good with that. Even with speakers bias can infect our perception, but practically speaking speakers do sound different, so I'm fine with my sighted conclusions (or the reports of other people). If I think I hear a difference between, say, AC cables or music servers...as I seemed to at points!...knowing this is less technically plausible, I prefer to double-check my impressions controlling for my bias. And, in the case of both those items, it turned out I couldn't really tell a difference once I didn't know which I was listening to. I found that helpful.
But then we get in to what I see as more gray areas, for instance differences between amplifiers. Hearing differences between well designed solid state amps (which are appropriate for the load of a given speaker?). That's in to more technically controversial areas so, before I presume a difference I'd prefer to see measurable differences that suggest audible differences and/or someone passing listening tests controlling for bias.
Difference between tube amps and solid state amps? Well...that's in to a technically plausible, and generally widely accepted "there can be measurable/audible differences." And...hey...I am an inveterate Tube Amp guy because I perceive distinct differences between my CJ amps and the solid state amps I've tried. I'm more comfortable provisionally accepting
I'm hearing these differences, because they are at least plausible...though of course it COULD have been a bias effect "Tubes are going to sound warmer, more lush...because...tubes." (As it happens, even there, for kicks I did a blind test between my Benchmark LA4 preamp and my CJ Premier 16SL 2 preamp, and easily and reliably discerned between them...not all blind tests are "negative" for differences).
But then, I also got in to tube rolling. There are arguments for why different tubes can make a difference...but also arguments for why it's often unlikely they will make an audible difference. Over on the ASR forum there are some quite skeptical and would like to see solid data for these claims rather than "I heard a difference."
The thing is: I respect that. Do I seem to perceive a difference between different types of tubes in my CJ - e.g. swapping the 6550s for KT120s? Hell ya!
But I UNDERSTAND that someone else can reasonably be skeptical and not want to rely just on my say-so. I have no problem whatsoever with someone at ASR remaining skeptical. Doesn't hurt or bother me at all.
And, unlike so many audiophiles I've encountered on forums, I'm NOT going to take my ears as So Infallible that I will call anyone skeptical a blinded dogmatist, or cast aspersions on their experience, or their ears, or their gear.
That's the thing with the Golden Ears approach: It's infallible, and allows the Golden Eared person to believe his claim in the face of any objective counter evidence, and to ALWAYS be able to claim "Well, I guess I just have more sensitive hearing and experience than you do...you poor person..."
I could claim to hear angels singing in the background when a certain AC cable was in use. "Oh, you don't hear it too? You must not have my Golden Ears." What if someone says "Can we do a test where you don't know which cable is in use, so we are testing JUST your ability to hear what you claim?" Well, if I reject that method, or the relevance of measurements, then I just leave my claim untouched, unable to be falsified. I can go on forever just claiming "I can hear things YOU can't."
But...nobody else is obliged to take that claim seriously. Yet it's amazing how often the "
My claims have more validity because I've played with much more expensive equipment than you have" response, which of course does not address the central problem - the method a person is using for his conclusions - in the first place.
Putting it another way, the whole cable thing would be much less of a morass if we could be confident that we subjectively sonically prefer the more expensive cable every time.)
Like I mentioned before, another way the cable thing would be much less of a morass is if audiophiles followed standard
electronics theory, where the characteristics and requirements for cabling are quite well defined. It's when people start injecting magic dust in to the pursuit, and buying in to countless manufacturer claims and audiophile shibboleths "everything can make a difference" "everything needs burn in" etc, that can lead to a morass.
*I'm just raising a counter-example as a way of thinking about it. A way that many audiophiles IN FACT think about it, and IN FACT don't fuss about the "morass" that many other audiophiles get in to with cabling. Personally, I look mostly at the basic requirements I need to meet with cables, and don't fuss beyond that. It's not the case I'm unfamiliar with high end cables.
I've been in this hobby a long time and have had access to all sorts of cabling. I've heard my own speakers on cabling costing up to $50,000 or more (e.g. high end Nordost, Crystal cable etc). Sometimes my current system has had Nordost, or other high end cables, on lend when I've been in a fix requiring some cables. But, for instance, I recently had on loan a pair of very well reviewed $4,500/pair XLR cables going between my Benchmark DAC and Benchmark LA4 preamp - among the most technically transparent audio devices you can buy. I had to replace the "high end" XLR cables so I just bought good pro grade XLR cables for around $50. I couldn't detect on iota of "lost information" with the cheaper cables. Which is just as electrical/cable theory would predict. So, I'm familiar with high end cabling. No it's not a morass for me - I don't fuss over it (and certainly don't worry about "break in"...).
But, to each his own...
Cheers.
