They are 2425 on 2344 and 2404. There is no eq. Both are simply piggybacked of the main drivers but pulled down in level to such a degree that they are not audible from the listening position nor have a measurable effect on the in-room frequency response. The experiment started off as an attempt to alleviate a mild irritation that I only became aware of after more than 10 years of listening. Trebles had a very mild tendency to "hang around" the tweeters, blooming in neither space nor energy. Not in lateral distribution but in height and depth and critically "bloom". I think this "bloom" maybe what Duke is referring to in a little more scientific way than I can? Borrowing from "conventional" speakers and a bit of Hiraga, I added 2404. The effects were not subtle at all. 2344 was an almost "what if" idea and started off as an equally crude experiment that ended as "that's perfect, don't mess with it" unscience.Hello
Those look familiar. 2432 and a 2404?? Do you EQ them flat or just leave them be with no CD compensation??
Rob
Regarding horns playing forward; IMO there are 3 factors: 1. Hornish sort of speakers are big and most lack bass. So they are shoved against back walls. Like any speaker against a wall, the image will be flattened and forward. 2. The way most hornish speakers are presented will be with an up-tilted upper mid and lower treble response. This tends to flatten soundstage and push images in that soundstage forward. 3. Carolus drilled this into me: In any multi-driver horn speaker, it is critical that all drivers above bass must be physically aligned. I can add that in my experience with TAD/Kinoshita type semi-horn speakers where this is not doable some sort of electrical delay is critical to get sound staging and imaging correct. TAD (and Kinoshita) achieves this by using an asymmetric 2nd order highpass but much higher order lowpass crossover in order to delay lf output.
I am sure all these effects can easily be compensated for in the digital domain but I am not into digital or digitising analogue signals so cannot comment on DSP except saying that I have never heard it sound pleasing to my ears. That does not mean it cannot be good.
As always just my personal opinion based purely on my limited experience.
